First post, by nuninho
Hello, guys. grinning face
-> Watch with the description
https://youtu.be/6Ji2JTjB9xY
Games failed = glitches, artifacts or black screen. hahaha! grinning face
PS: I don't need any help. winking face
CPU: i7-12700KF
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 - NEW beaming face with smiling eyes
Opt. disc: LG BD-RE writer BH16NS40
HDD: SATA 1TB
SSDs: OCZ RD400 0.5TB+Crucial MX500 2TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 21" Sony E530 beaming face with smiling eyes
Reply 1 of 9, by Gmlb256
Honestly, I find running real DOS on modern computers to be a complete waste of time and would rather use emulators on those. Hardware support isn't adequate even with the SBEMU TSR for Sound Blaster emulation.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 2 of 9, by nuninho
Gmlb256 wrote on 2023-05-30, 16:16:
I don't care any sound card due to my mute. winking face
CPU: i7-12700KF
HDD: SATA 1TB
Reply 3 of 9, by zyzzle
But, more people should care about running DOS games bare metal. That's why the SBEMU project is so fantastic. It solves many, many problems for using sound in DOS games, via a wrapper which recognizes newer PCI sound chipsets and makes them usable by working in these "new" DOS systems.
Now, we need enough similar interest in fixing the hardware side of things via a sort of generic VGA simulator, and one which uses a pageframe and provides VESA support for higher-resolution games on bare-metal. The concept is similar: a kind of abstraction layer which won't be an emulation (which is dreadfully slow like DOSBOX), but a sort of conduit which can fix all the bugs intentionally introduced into modern vBIOSes, like lack of VGA support, etc.
In short, like a "revived" Univbe, but supporting newer Intel video BIOses, Nvidia BIOSes. Many would pay for such a wrapper, I believe. There's money to be made. But, even more, there a lots of very smart programmers who could contribute to such a project. Many are on this very forum. A few have even written small BIOS 'fix' tools. (I think ruthan is one of them, as well as RayeR).
Reply 4 of 9, by willow
zyzzle wrote on 2023-05-31, 04:43:
But, more people should care about running DOS games bare metal. That's why the SBEMU project is so fantastic. It solves many, m […]
Have you a link for sbemu project because I don't find anything on google?
Reply 5 of 9, by Gmlb256
willow wrote on 2023-07-09, 11:58:
Here: SBEMU: Sound Blaster emulation on AC97
Reply 6 of 9, by LSS10999
I'd love to see a solution for "fixing" the VGA functions (as well as VESA/VBE) for new video cards. I think UniVBE existed at a time when many video cards did not have VBE or only lower versions like 1.2, and became obsolete when later video cards all getting native VBE 3.0 support. Now with new video cards still claiming to be VBE 3.0 compatible but in reality not (functions marked as supported but calls would fail), and it keeps getting worse with later generations, there's once again the need for such a tool to make them "really" VBE 3.0 complaint.
Reply 7 of 9, by clb
Haha, what an awesome video! beaming face with smiling eyes
Hmm, Chris's 3D Benchmark only 102.5 fps.. something must be capping that benchmark.
Too bad about UNIVBE not detecting the graphics card. I wonder what my SNOOP.EXE would say about that card.. (see SNOOP.EXE: (S)VGA adapter info tool and CRT Terminator config utility )
Was super surprising to see that Pinball Fantasies worked - that game does the most custom things to video modes possible..
Reply 8 of 9, by zyzzle
clb wrote on 2023-08-08, 22:36:
I'm super surprised the 4090 even *works* in DOS. It must have at least some legacy 16-bit vBIOS. That is encouraging, for it means a utility which "fixes" (patches) its BIOS could be made as a TSR. The same goes for other "modern" onboard BIOSes with broken VBE3, 24-bit colors, and inability to enable MTRRs on such onboard, buggy 16-bit video BIOSes. Many of these even have *all* sub 640x480 modes and *all* 8-bit modes completely disabled / non-existent! Such as all onboard AMD Ryzen vBIOSES I've ever booted into DOS.
Chris' 3D benchmark probably doesn't report higher fps because the MTRRs of the write-combining cache mode are not set or even possible to enable in that card. If MTRRs for WC could be enabled, no doubt the 4090 card would score in the thousands of fps on the Chris 3D SVGA benchmark.
I know, at least on Intel i3/i5/i7 internal onboard video, the last system that I have that can enable write-cache combining MTRRs is a Broadwell family CPU (i5-56oo) with Broadwell onboard graphics (Intel HD graphics 5600). All my 6th gen and above systems freeze when trying to enable the proper MTRRs using write-combining option of RayeR's MTRRLFBE utility, as well as other such programs.
Many of these onboard graphics also fail to set the VBE mode properly and / or lack such support. For example, on all my intel systems at 6th Gen or above, using some games to manually set 640x480 and up results in black screen and complete system freeze, while others like Quake, Quake 2, Need for Speed, etc work very well with VBE modes. I think the problem is a lack of support of either a real VESA2 linear framebuffer and / or VBE3 bugs in setting / enabling 640x480 on up -- resulting in black screen and freeze.
Reply 9 of 9, by LSS10999
zyzzle wrote on 2023-08-09, 02:37:
I'm super surprised the 4090 even *works* in DOS. It must have at least some legacy 16-bit vBIOS. That is encouraging, for it m […]
RTX cards indeed work in DOS... just barely. VBETEST can be used on these cards but only a select few resolutions are listed as available. With older video cards, you can access more resolutions.
On the other hand, these cards' VGA BIOS footprint is relatively smaller than older generation cards with better VGA BIOS, that with these cards, I could access a bit more UMB in DOS.
It feels as if the functions in question are there but no actual code at all. Either does nothing or always returns a fail, and it's up to the calling program to handle the failures.
