Fixing up a Soyo SY-5TF Socket 7 Motherboard
First post, by CalamityLime
Hello everyone!
I had made a thread about fixing up a PC in the past that you can find here if you're interested!
It was fun to make that thread so here is another repair thread, Unlike my previous thread, this one will update in real time since I haven't so much as given the board power yet.
So the motherboard I nabbed is a Soyo SY-5TF which thankfully has an Ultimate Retro page with some specs of the board. I purchased on eBay for 10€ with 20€ shipping from Spain. The motherboard arrived today in decent packaging but cracking open the package revealed it's first issue, it stinks. I opened the box and gagged.
It smelled like it was left out in the open is a very musty shed likely stored with some oil based paint that has splattered the board in a few places. The box that the board came in was decent but there was very little bubble wrap and no ESD protection. Thankfully there doesn't look to be any shipping damage and considering it smells like it was left in the open, if ESD was going to kill it, it would have by now.
It was going to get a wash because it needs it. Before washing since that could wash away any clues of damage it needed a visual inspection.
Next part will be about the few blobs of paint! I'll write that up in a bit.
Be Happy, it's only going to get worse.
- Projects
Limes Strange 3D models
USB-2-232
Reply 1 of 240, by majestyk
This is a nice HX board, it will take some effort to get rid of that chocolate frosting though.
Reply 2 of 240, by CalamityLime
Part 2: 74HCT14N
Getting the board on the bench for inspection revealed not much at first. The most noticeable issue is the dirt that I think this image shows the best out of the ones I took.
Image Dropdown
file.php?mode=view&id=138263
Ignoring the smell, I checked the second most obvious issue, what looked like a leaky cap.
This is in fact not a leaky cap, it's a cap that had a blob of varnish dripped onto it. I bought the board expecting the caps to need replacing based on that cap and what turned out to be a "spot of clean" beside another that looked like liquid in the sellers photos. I do find the blob of varnish on the cap to be almost impressive. It didn't drip down the body of the cap, it just plopped on there and stayed there. You couldn't do it if you tried.
Image Dropdown
file.php?mode=view&id=138264
What was an issue that I wanted to get at before washing the board is this inverting schmit trigger. I looks like it had a blob of varnish dripped onto its pins. While I don't think the stuff is conductive, I wouldn't think it's good for the chip to have varnish on it's legs. I decided the easiest thing to do is to desolder the chip, clean it and put it back with a socket. With some struggle, I got the chip out without any damage that I noticed.
I put it in a jar of IPA I use to soak things while the board takes a bath. Hopefully that'll make it easier to clean.
Image Dropdown
file.php?mode=view&id=138268
file.php?mode=view&id=138267
While soldering I couldn't help but notice this cap awkwardly soldered to the back of the socket 7. Anyone know what it is?
Image Dropdown
file.php?mode=view&id=138269
I did also check the caps for any juice as well as making note of their values and specs. They all looked good and there was no shorts between voltage rails and ground.
That's all I can take of the smell, time for its wash.
- Projects
USB-2-232
Reply 3 of 240, by chrismeyer6
The cap on the back of the socket is most likely a factory repair you see that kinda of stuff alot. That was one very accurately dropped blob of varnish on that cap. I dont think I'd be able to pull that off if I tried.
Reply 4 of 240, by CalamityLime
Part 3: Bath Time
In a last bit of preparation before bath time I took any socketed chips out of their sockets and tried to take off the soyo sticker but that just disintegrated. Oh well.
So it got a simple bath of Dish Soap and water. I scrubbed the sockets with a toothbrush and washed the main board with a paint brush.
Nothing very exciting but a nice bit of dirt came off of the board.
Image Dropdown
file.php?mode=view&id=138274
After a very very long rinse to make sure there was no dish soap hiding under any sockets or in the CPU socket.
Now with the dust out of the way we can see really the bits of varnish. One pin of the top isa card has varnish on them and there some varnish in the socket on the plastic. More than likely that can be cleaned off or chipped off.
The bottom ISA slot is a bit worse and I think trying to save it might be a waste of time.
On the up side, the board looks clean now and the smell of it is going away.
The nauseating smell of must has been replaced with the wonder solvent smell of IPA I sprayed the motherboard with to displace the water.
I do have some acetone that makes short work of the varnish, so hopefully the cleaning should be simple, though I am unsure of the bottom ISA slot.
Now I'm waiting for the board to dry, I'll have to get some socket 7 CPU to try booting the machine with and of course do something about the RTC battery.
- Projects
USB-2-232
Reply 5 of 240, by CalamityLime
I had a bit too much fun drilling out the battery contacts.
- Projects
USB-2-232
Reply 6 of 240, by Sphere478
Props to your patience with the dallas.
I just order aftermarket replacments.
Ooo hx board.
Have you looked up your clock gen?
Can you get a pic of the whole socket from the rear?
Sphere's PCB projects.
Reply 7 of 240, by Sphere478
If you don’t have a cpu yet, you can probably get a k6-3+ working in that. (Fastest cpu) if that’s the direction you wanna go order a k6-2+ 570 and Check out the 2+ to 3+ mod thread in my signature
But we can do some voltage checks before you order.
Though I suggest something more fun might be a tillamook or low voltage cyrix. Rise cpus are fun also.
Btw, this board should be able to make use of several features on my tweaker lineup.
Reply 8 of 240, by CalamityLime
Sphere478 wrote on 2022-05-28, 01:04:
Props to your patience with the dallas. […]
Ooo hx board.
The clock chip is a CY2260sc-3
Pin one for the socket is on the upper right hand side.
-Lime
- Projects
USB-2-232
Reply 9 of 240, by CalamityLime
Part 4: Good Varnish News.
I wasn't expecting this but I'm glad this worked out.
Like I said before I was leaving a chip soak in IPA to hopefully loosen the varnish on it. After washing the motherboard and spraying it with IPA to displace water, I went back to the the chip in the IPA.
I picked it up with tweezers and poked the blob of varnish with my finger nail, to my amazement the varnish had turned to jelly in the IPA.
Quickly grabbing the board and giving it another spray, I got to work remove blobs of varnish from the ISA slot and it all came off fairly simply. The only issue was two pins where the varnish encased the pins and didn't stick out enough to let me grab it without bending the pins around.
So in an unexpected piece of good news I got the isa slots cleaned out.
I did leave the blob of varnish on the cap and it did solidify when the IPA evaporated off of it.
There was also a scratch on the back of the board that was deep enough that I can see copper of two traces. They are not cut thankfully so I should just need to cover them up with something and job done.
So good news.
- Projects
USB-2-232
Reply 11 of 240, by chrismeyer6
Nice job getting that board cleaned and fixed. For the exposed traces I usually use my wife's clear nail polish.
Reply 12 of 240, by chrismeyer6
That cooler should fit your socket no problem.
Reply 13 of 240, by CalamityLime
chrismeyer6 wrote on 2022-05-28, 02:20:
I thought so at first but one of the images in the reviews told me otherwise. The reviewer said it would work with a socket 7 but they had the plastic cpu socket arm that sits flush like the later sockets but mine has a metal arm that sits a shade above the cpu and that might interfere.
EDIT: Since it doesn't look like there's a gap for the cpu arm like their startech's proper socket 7 coolers.
Ah well.
- Projects
USB-2-232
Reply 14 of 240, by CalamityLime
ah, actually I'm wrong.
I found a listing on ebay for the same cooler and it clearly shows a little cut out spot for the arm. Not much of a one but it just needs something.
I'll order it on amazon, seems to be the cheapest option.
Well, this is strangely exciting.
- Projects
USB-2-232
Reply 15 of 240, by Sphere478
CalamityLime wrote on 2022-05-28, 02:18:
Quick question
Will this cpu cooler fit the socket 7?
https://www.amazon.co.uk/StarTech-com-60x65mm … C47&sr=1-1&th=1
You know, with newer cpus you always try to find the biggest and beefiest cooler. The one you found looks like it is for a socket a which will also work on socket 7 but I prefer ones that only use one tab and low tension.
See socket 7 really doesn’t make much heat, like 30w tops?
Anyway, if you want a nice easy heatsink grab this one
https://www.ebay.com/itm/254093276215?epid=19 … sAAAOSw-ZZdI0Vo It’s so low hassle and way more than the cpus need.
If you want to do some overclocking grab this one
https://www.ebay.com/itm/173850646045?hash=it … CQAAOSw8d9U1YWa
It’s about as big as you can go and still clear most motherboards.
I grabbed these clips for the copper one
https://www.ebay.com/itm/390963781079
Bend them back a little to take some of the tension off.
Watch out for the width of some of the athalon and celeron/p3 ones.
Another good one, if you can find the three wire version of this one, it’s pretty good. You’ll want those clips for that one too.
Buy those clips, bend them for less tension. They are very handy
Reply 17 of 240, by majestyk
The large Athlon cooler would blow the air in the wrong direction.
It´s essential the heatsinks of the VRMs are IN the airflow since they dissipate about as much heat as the CPU.
With the Athlon cooler they would have virtually no cooling.
This is an issue as soon as you run a Pentium MMX or AMD K6 and even with a K6-III+ because although it consumes less power the voltage-drop at the regulator is higher.
Reply 18 of 240, by Sphere478
CalamityLime wrote on 2022-05-28, 01:34:
The clock chip is a CY2260sc-3 […]
Ooo hx board.
-Lime
Some bad news…
https://www.datasheets360.com/pdf/-1221703239049012746
Your max fsb is 66 mhz.
But don’t worry, that’s enough for 400mhz k6-3+ thats enough to run sims 1 pretty well.
Reply 19 of 240, by Sphere478
Ooo hx board.
-Lime
That capacitor doesn’t seem to be doing any mod that I am aware of. Probably there to fix some kind of design defect.
