First post, by oeuvre
- l33t
Nabbed one of these bad boys! No side window here. Pretty cool mid-2000s ATX case.
Another picture of the box. The most difficult part of this build was honestly removing the "standard" I/O shield it comes with.
Ultra ULT31584 Wizard Blue ATX case
Corsair CX750M power supply
ASUS Z170 Deluxe motherboard
Intel Core i7 6700K 4GHz quad core processor
Thermaltake Contac Silent 12 heatsink
Scythe 120mm PWM rear fan
Arctic F8 80mm PWM front fan
MSI AMROR Radeon RX580 8GB PCIe video card
32GB DDR4 3200 RAM (2x16GB)
Samsung 970 EVO NVMe 512GB
Seagate 2TB 7200RPM HD
DVDRW drive
2xFront panel USB 3.0 ports
The USB 2.0 ports are connected but the FireWire isn't
Optical drive + USB 3.0 ports
Side panel. Removed the shroud it came with.
The rear end
The insides! Mostly black and white theme going on here. No RGB lighting or any of that.
Another view
Closer look at the rear fan + heatsink + RAM slots
Bottom half of case
BIOS screen
Windows 10 desktop
Here it is!
It's ALIVE!
