Lo-Tech ISA-USB
First post, by tereg
Good day everybody.
So I build this kind of adapter by the scheme of lo-tech (https://www.lo-tech.co.uk/wiki/Lo-tech_ISA_USB_Adapter)
And of course I want to test it, but find the problem that I can't download bios and flasher for this device from the lo-tech site.
Is there chance somebody could help me with this?
Reply 1 of 3, by digger
Maybe it was added to the wiki later, but now it explains further down the page that you need the same flash utility as the one that is used to flash the L-tech XT-CF card. That utility wiki (which contains the download link for the utility) is linked to from the wiki page.
As for the correct BIOS, at the bottom of the page that you linked to, under the section "Downloads", you can see a link named "Alpha BIOS binary".
I had no problems downloading the linked ZIP file.
But here are the direct links to both the flash utility and the BIOS, just in case:
* https://www.lo-tech.co.uk/downloads/XT-IDE/lo … ash-utility.zip
* https://www.lo-tech.co.uk/downloads/isa-usb/i … imental-rom.zip
I also took the liberty of uploading both ZIP files to VirusTotal to have them scanned for any malware, even though they came from the original site. None was found. 😉
Good luck! 😀
Reply 2 of 3, by AllTinker
I really want one of these cards, but it seems like they aren't being sold anymore - looks like I might be too late.
I've checked on the TexElec Lo-Tech page a few times over the past months, but it hasn't (re)appeared as of yet...
itch / Bluesky / web
Reply 3 of 3, by rjbrown99
FWIW, I ordered this one:
https://www.aliexpress.com/item/33037705524.html
Different board,m same idea. Took 7 weeks to arrive, will see if it works. My use case is just as a USB port under W95 and have not tested yet.
