First post, by TheOligopolist
Windows 10 seems to break VirtualMIDISynth the majority of times it does an update. The "Default MIDI Output Device" selection becomes greyed out and seemingly, the only way to fix it is to do a reinstall. It's not a huge deal, but it's still pretty annoying.
Has anyone else been experiencing this and know of a way to stop windows from breaking it?
Reply 1 of 8, by PhilsComputerLab
Interesting, can't say I've noticed this.
YouTube, Facebook, Website
Reply 2 of 8, by MrEWhite
Works fine here with the latest beta.
Reply 3 of 8, by Licentious Howler
I've never had that box be anything but grey on Windows 8.1, and I presume 10 would be extremely similar (I can't get updates working yet, so I can't test on 10), so you can try this workaround that I've always used... maybe it'll solve the problem, or maybe Windows updates will kill it either way:
Use regedit and go to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32
and look for a key called "midimapper", change its value data to:
"VirtualMIDISynth\VirtualMIDISynth.dll"
Do note that this does not "ungrey" the box, it just points Windows to the default MIDI device and should still make it work globally for all MIDI playback in the kernel as far as I've tested.
Hopefully it works for you.
Reply 4 of 8, by citrixscu
I thought Win10 disabled midi mapper user tuning so VM synth will always be gray. Most apps that are affected allow for selection when required.
Reply 5 of 8, by mudlord
Licentious Howler wrote:
I've never had that box be anything but grey on Windows 8.1, and I presume 10 would be extremely similar (I can't get updates wo […]
Does it work from Windows 8.1 to Windows 10?
Reply 6 of 8, by ElBrunzy
I use coolsoftvirtualmidisynth for to listen .mid with my HUGE soundbank on windows media center hack running windows 10 (x86 tho...), thanks for the headsup as I didnt realised it was broken for it work such flawlessly.
Reply 7 of 8, by JJXB
my biggest issue is how Windows 10 (x64) keeps removing the device from being used at all and i have to either run a reg file i made to get it to see the virtual device again (doesn't remove the files, just the entry in the registry) or flat out reinstall.
Reply 8 of 8, by ElBrunzy
not to mention how win10 love to remove windows media center hack's too 🙁
... what was the topic of this thread ?
