First post, by Alkarion
- Member
I tested the virtual Modem with Dosbox 0.61 with several games and so far I had no success. I set up a local network with two computers which are able to ping each other. Command and Conquer won't recognize the modem at all and Tyrian tells me I have no UART, probably hardware-near programming.
The games which actually recognize the virtual modem that I tested are Kingdoms at War and Warcraft 1. Dialling even leads to Dosbox saying: host 192168000049 port 17. But in spite of activating the answer mode on the other computer the games complain that they get no dialtone.
Has anyone tested the virtual modem successfully? If so, with which game?
