First post, by Gramcon
I was using my 386 today in DOS when suddenly every keypress would just print gibberish. I rebooted the computer, and it immediately spits the beep code for keyboard controller failure and will not POST. It's a PS/2 style port integrated onto the motherboard. I unplugged and reseated everything, cleared the CMOS, etc., no luck. Anyone have any suggestions to fix, or am I up the proverbial creek? Thanks for any suggestions.
Reply 1 of 5, by Robin4
Maybe some battery fluid over the motherboard near that keyboard connector? Also check if the connector self is in the right shape..
Reply 2 of 5, by smeezekitty
Check the board for physical damage.
On a few boards the controller is actually socketed. If it is, make sure it is making good contact
A 386 board with PS/2?? Wow that is uncommon
Reply 3 of 5, by Gramcon
Thanks for the help! The battery was a plug-in type that I removed immediately after I got it. I sprayed Deoxit on the IC nearest the battery connector that had a tiny amount of corrosion near it. I also sprayed around the keyboard connector. Not sure if you're supposed to use that stuff on motherboards, but It fired up after that...hopefully it will last.
Yeah, a 386 with PS/2. Check out the pic. At the top right is an AMD 386SX-33. Sixteen-bit connector in the middle is for an ISA riser card. It's from a DECpc. Neat little box.
Reply 4 of 5, by smeezekitty
That looks a bit like my old packard bell 486 board (that died) with onboard video, PS/2 keyboard and mouse
and one ISA slot that is designed to be connected to a riser.
But strange to see on a 386. Usually 386 was way before onboard everything
Reply 5 of 5, by kixs
IBM PS/1 has also everything on-board - I have one with 386SX.
Requests here!
