First post, by hobossuck
can anyone help me work ace ventura on dosbox it doesn't work when i run the ace.exe in dosbox it just says this program requires Microsoft windows i tried running it on my normal computer without dosbox but i use 64 windows 7 so it doesn't work.
Reply 1 of 8, by SKARDAVNELNATE
If it's for Windows 3.1 you can install that in DOSBox.
Reply 2 of 8, by hobossuck
yes it is but how do i install windows 3.1 on dosbox
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
Grab your win3.x installation disks, copy them into one directory, mount the
directories according to the regular guiding, then install it.
Reply 4 of 8, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 8, by irency
Thanks for the link you posted above, robertmo!!! That helped me to fix my issue.
Reply 7 of 8, by marcelogabriel
Only for the records.
Perhaps you would like to run Ace Ventura inside dosbox, but this game can run under Win7 changing the compatibility mode of ACE.EXE to WinXP SP2. It will run full screen.
Regards.
Reply 8 of 8, by leileilol
However.
That only will work, if the host is 32-bit, which is a minority now, so you can not just give this advice to anyone 2 years later.
Regards.
long live PCem
