First post, by Neville
I just set up "cannon Fodder" with DFR, and although the emulation seems alright with default values (cycles & core =auto, 32 Mb RAM, etc) it's not very playable, the mopuse pointer can't be controlled.
It looks like a mouse sensibility issue to me, but can't find a correct value. The closest I've seen to playable is setting mouse sensibility within DOSBox at 50%, and that's still a far cry from the real thing.
Any ideas?
Reply 1 of 10, by wd
Rank DOSBox Author
DOSBox Author
32mb is no default value. Try without a frontend, using a clean dosbox.conf
and see if fullscreen makes a difference. CF1 works just fine here.
Reply 2 of 10, by Neville
I'll be damned... it DOES work with plain DOSBox. There must be something off in the config I'm using within DRF.
Thanks for the help.
Reply 3 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
please post if you figure out what is wrong
Water flows down the stream
Reply 4 of 10, by Neville
I think I got the problem, it's the "autolock" feature. If it is on, the game behaves normally. If it is off, the mouse behaves errativally.
Can anybody check this against their versions of the game?
Reply 5 of 10, by wd
Rank DOSBox Author
DOSBox Author
Which autolock? Does it behave the same if you change the autolock value
in your clean 0.72 dosbox.conf?
Reply 6 of 10, by Neville
Mouse autolock. And yes, it does happen under DOSBox v0.72 and a clean dosbox.conf. I just tried it before posting this, to be sure.
Again, it would be nice if anybody else could reproduce it.
Reply 7 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
well autolock=false is less compatible with games that read the mickeys instead of the coordinates.
you can lock the mouse btw with middle mouse button for those games.
Reply 8 of 10, by Neville
Thanks for the quick answer. BTW, are there any games known to respond badly to autolock=true?
Reply 9 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
no, autolock=true is the most compatible.
autolock=false exists for people that don't like the fact that the mouse is locked to the window.
but it is always less compatible.
Reply 10 of 10, by Neville
Good to hear that. I've just suggested Alexander to make "autolock=true" the default setting in DFR, and asked him to check if any other options are set different in DFR's default settings than in the default dosbox.conf.
