First post, by Clive
In Dosbox v0.70 my Microsoft Sidewindwer joystick works in that it is detected and provides some input. However it does not work properly whatever settings I try in the conf file. The best way to describe the problem is to say that in the game One Must Fall, there is a joystick configuration screen with a 3x3 grid. The sidewinder will only "light up" the top row and the bottom row. It will not operate the middle row, which of course includes the centre "at rest" setting. I have no problems in Dosbox v0.65.
Joystick: Microsoft sidewinder with gameport connector (not USB)
Gameport: Creative Audigy soundcard
I have tried setting cycles to a fixed value (6,000) and [joystick] settings in many different ways, currently as:
joysticktype=2axis
timed=false
autofire=false
swap34=false
buttonwrap=false
The problem remains 🙁
Clive
