First post, by DustyShinigami
- Oldbie
Okay, so I recently learnt about DOSLFN, downloaded it, and I have it set up in my autoexec.bat file, but how exactly do you use it? I checked over the readme, which only seems to explain about its background, but not how you configure/use it. Even with it enabled, I've noticed that existing folders are still 8.3 long and folders are structured like CDIMAG~1. Is there a way of configuring it so it changes existing folders? Or does it only work for new folders?
Thanks
OS: Windows 98 SE
CPU: Pentium III Katmai 450MHz (SL35D)/Pentium III Coppermine 933MHz (SL448)
RAM: SK Hynix 128MB 100MHz/Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/Geforce 128MB 4 MX 440
Motherboard: MSI-6156/Abit BE6-II
