First post, by uridium
- Newbie
Greetings!
I'm re-doing my IBM PS/2 56SX MCA system with 8mb ram.. fun little beastie.
I've got PC-DOS 7.10 rev0 running and have been fiddling with FAT32 partitions.. but I digress.
I wanted to install QEMM9 so I pulled out my disks and installed.
Annoyingly, when the line in my CONFIG.SYS for:
DEVICE=D:\UTILS\QEMM9\DOSDATA.SYS
Is executed, the system freezes. I've tried env variables in the CONFIG.SYS:
1. DOSDATA=1
2. DOSDATA=UMB
No change and it'll freeze when DOSDATA.SYS is loaded. I've put it as the first line in the CONFIG.SYS and again same.
Anyone know if there's some sort of flags I can call DOSDATA.SYS with so it'll work? Or any others I can experiment with?
Thanks in advance for the time. All suggestions appreciated.
Regards,
Al
