First post, by Ramenman
Hello friends of the old PC!
I recently became interested in this horrible beat'em up and its historical interest related to the Tiertex company.
The versions that circulate on the internet have the EGA files but also the CGA. That is, it is not like the case of other preservations where only the EGA files were extracted.
In this case, when loading CGA, the game only plays the music through the beeper. However, in EGA it works perfectly. If I choose CGA mode with the emulator in EGA mode, EGA comes out.
The executable file is a .COM, does anyone know if there is a command to activate those CGA files that are there? If you do a "DIR" you will see that each enemy has a file with its corresponding version in CGA.
This game deserves to be played from its worst version 😀
Thanks
