First post, by informatyk
My turbo switch broke during removal from the front panel of the case. It looks like a regular computer power button, but of course it stays pressed when pressed, not like the reset or atx power buttons (I couldn't find their technical names either).
https://download.marpio.net IE4 compatible retro software download site
Reply 1 of 9, by darry
Look for a latching pushbutton switch in the right form factor.
Reply 2 of 9, by BitWrangler
So far I'm figuring description is gonna be something like subminiature SPDT pushbutton, plunger cap, latching, but not found stock anywhere yet.
Reply 3 of 9, by jakethompson1
When converting an ATX case to use AT-ATX converter on the power supply, part of what has to be done is convert the power switch from momentary to latching. I have used E-Switch TL2285EE for that. It should be the same as a turbo switch, theoretically. It doesn't come with any wires attached though.
Reply 4 of 9, by oso2k
BitWrangler wrote on 2024-10-04, 22:43:
I think you can use one of these https://www.amazon.com/gp/product/B089RHBYGC/ . They're latching IIRC. I used them in my EMM8088 build in an ATX case.
Reply 5 of 9, by jtchip
oso2k wrote on 2024-10-05, 00:45:
No, power and reset buttons are momentary switches, the description confirms it:
Desktop PC motherboard ATX power reset switch cable, red green LED indicator, momentary switch button, fits most desktop computer host cases with front panel button.
Reply 6 of 9, by BitWrangler
I have actually being having trouble with some glitchy turbo switches lately and was meaning to do something about it. But after a lot of searching it did seem like Amazon had the best options. I measured two or three case switches and some of the seemed under 8mm, some seemed to be 8mm and some seemed to be a little over 8mm, so I thought screw it, I'll get the variety pack, whatever fits fits, and I'll use some of the others for clock jumper extenders. https://www.amazon.com/DAOKAI-Locking-8-5x8-5 … /dp/B0BCK9JDWY/ if you aren't into soldering stuff up, you could get some female to female dupont connectors and strip pairs or threes of wires off to hook up with. Ppl have been saying that duponts aren't the most reliable for maintaining good contact long term (Guess that's like everything with sockets though) so may need jiggling/cleaning periodically.
Anyway, that's the way I am going, threw some in the cart, if that's not what is best for you, measure your switch and see if it's 8x8 or something else, and check other stuff on amazon, they seem to be calling those locking rather than latching.
Reply 7 of 9, by BitWrangler
My variety family fun pack arrived last night and they are good match for what I need, though one panel I have loose the 8mm are a match and another the 8.5mm. The button tops that come with are tiny, smallest size that will go over the plunger I guess, but look useful in the situation where you have a button missing...
Several ways you can go with that.. basically you'd be using those buttons as the attachment for a fabricated button, if it's a round one you could "turn" it from a piece of plastic or close grained wood to right profile and then slice the back off flat and glue or socket one of those little buttons on it. If it's a weird shape but you've got another one still sitting on the reset switch or something, you can do the old trick where you press the one you've got into modelling clay to make a face mould and then you can fill that with resin, let it set, or if you are really careful and make a jig to hold it in place, cast with one of these little buttons in place, otherwise, clean up the cast part and glue it on the back after. Also you may find a matching profile on another object, end of a marker pen, some bottle cap, and you can cut that down and glue on. Maybe also if you are "half good at 3D modelling for 3D printing" you could get something more or less the right shape and wouldn't have to do 200 prints to get the plunger fitting right.
Reply 8 of 9, by Horun
Nice ! Good find BitWrangler !
Reply 9 of 9, by oso2k
jtchip wrote on 2024-10-05, 00:50:
OP is looking for latching buttons. Maybe I linked to the incorrect buttons I used. It might have been (https://www.amazon.com/gp/product/B08GQ42YDJ).
