First post, by FreddyV
I just got a 80286 and I would like to compare my player (Mod Master XT) with 286 compatible payers.
I tested Mod Play pro, but It is not stable (Crash after some seconds)
Of course GLX will work.
Ideas for other players to test ?
Reply 1 of 3, by mkarcher
FreddyV wrote on 2021-03-26, 09:59:
Hi, […]
I used Visual Player on my 286-12 machine with PC Speaker and Parallel Port DAC output without problems. With a DMA capable sound card, it should work even better.
Reply 2 of 3, by CrossBow777
One of the first MOD players I know I used on my 286-16 was the WOW player as it supported my SB Pro back in the day that I had? I'm sure there were a few others I messed with but I do remember using that one quite a bit although I recall it wasn't a very accurate player.
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 3 of 3, by fragmentfi
Back in the day I mainly used DMP (Dual Module Player) on my 286. Only the older versions (1.41 or older) will work on a 286.
