This is my first post here in a long time, but this warranted a quick post, for sure. 😀
I was checking through some saved eBay searches and for the first time ever I saw a Roland CM-64 for under $300, and it was in the US as well. It was listed for $150 "as is, untested" with free shipping. I offered $100 and the seller accepted it!
It had a ton of scuffs, marks and splotches on it in the pictures and it looked about as bad when I got it. A little scrubbing with a magic eraser though, and now I have this:
The attachment 20191226_143640 (1280x960).jpg is no longer available
It is has some dings and dents here and there, but it isn't even yellowed!
I took the bottom panel off and it looks rust-free so it at least hasn't been stored at the bottom of a scrap heap outdoors.
I used a compatible (but not original) power brick I had laying around and it powers on. I don't have any of my retro systems hooked up at the moment (just moved) but I got it running through DOSBox using a Roland UM-ONE and it WORKS! This is fantastic!
I took a peak inside and could just make out the firmware ROM that says 1.00. I've read that there are some quirks with early versions but I can't seem to find a download for a newer version.
Also, when I power it on with a cheap eBay-special 9v 1A (center negative) power brick, the power led flashes a couple times (also makes my headphones thump a little each time) before it powers on fully... so I'm not going to be using that. When using a 9v 1A Roland "ACI" brick from my SC-55 it works fine. The only other one I have available is a 9.5v 1.5A Roland "ACK" brick that came with on of my MT-200s. That extra .5v has me shying away from using it on the CM64 though. Anyone know of a good quality 9v 1.2A (or better) brick with a center negative connector that would be good for one of these old devices? It says to only use an "ACB" 9v 1.2A model. Original Roland bricks these days are about as rare and about half as expensive as the devices themselves though, so quality modern replacement would be nice.
