First post, by Presbytier
SO Installed the GOTY version on a Windows 10 PC latest updates latest drivers on all my devices. The game starts with a small black box in the center of the screen then it disapears and the game does not launch at all. I tried using DGvoodoo to see if it was some weird graphics problem but same thing. the game will not launch on a windows 10 PC.
"Never pay more than 20 dollars for a computer game" - Guybrush Threepwood
Reply 2 of 4, by Presbytier
Okay that launches the game thanks, but do you know how to get the NOLF Modernization to pack then to work sense you are bypassing the launcher?
Reply 3 of 4, by mrpenguinb
Create a shortcut for the main .exe I think (there is probably a separate launcher exe file). Open file location the shortcut if you don't know where the game is. Once you have created the new shortcut (for the game, not the launcher), view the properties of the shortcut and add
-rez NOLF.rez -rez NOLF2.rez -rez nolfu003.rez -rez NOLFCRES003.rez -rez NOLFGOTY.rez +DisableMovies 1
to the Target field in the path. Add it at the end, with a space between the last quotation mark of the path and the commandline parameter.
Reply 4 of 4, by Kerr Avon
Presbytier, I've just sent you a PM, hope it helps.
