WIP versions
Reply 920 of 1111, by Dege
lowenz wrote:
lowenz wrote:
Red Faction (Pure Faction -> https://www.purefaction.org/ ) + WIP57/58 + ReShade 4.2 -> No ReShade!
Up 😁
Crosire wrapper is working, so it's not a ReShade problem.
I gave it a quick go with ReShade 2.4.1 and it worked for me. There is no particular reason or change between WIP56 and 57 causing it not to work (like in case of VorpX).
Does it not work for you in general or just with a specific game?
BTW, Guys, thanks for the tremendous feedback! However I want to finish something (currently in development, will take some time) before switching to bugfixing mode again.
I'll have a lot to do. 😀
Reply 921 of 1111, by Dege
ZellSF wrote:
I think the current options should be good enough. I wish they were exposed in the Cpl though.
It's funny that even I myself prefer the CPL to editing the config file manually.
CPL of dgVoodoo1 had an extra tab for 'renderer specific settings' which could only be enabled through a context menu option ('Show renderer specific options').
I was thinking on introducing this into dgVoodoo2 CPL for GeneralExt/GlideExt/DirectXExt config sections, to have the possibility for reaching all of the config elements through GUI. This would bring GUI on par with manual edit but extra tabs would be hidden by default.
ZellSF wrote:
Why does the debug cpl give this warning?:
[4316] [dgVoodoo CPL] WARNING: Desktop bit depth (0) is invalid. It should be 8, 16 or 32.
Uh, bug in the config validator... 😊 Fixed, thanks.
Reply 922 of 1111, by lowenz
Red Faction (Pure Faction) only!
Reply 923 of 1111, by Deffnator
Dege, you should contact MS about dgvoodoo always being tracked and deleted by MS Defender.
Reply 924 of 1111, by djc5166
Is there a kind of database somewhere with games and versions of dgvd2 they were tested with? I know PCGW has a lot of references to dgvd2 on specific games, but I don't think I've ever seen an actual database.
Reply 925 of 1111, by Wastelander121
Good news: It seems to work with every UE3 game I've tested it on. Arkham Asylum has some graphical glitches with his cowl, face and cape. Borderlands 2 and PreSequel appear to be fine, as well as Dishonored.
Bad news. A couple of games refuse to start up, such as Arkham Origins Blackgate and Vanquish. The framerate can be a bit low/stuttery on some games too. In the case of Remember Me it ran at 10-15 fps before gradually reaching a solid 60. Reminds me a bit of how emulators do shader caching, if it's anything like that.
I've also had some luck getting dgvoodoo to work with Special K's DX11 mod tools. It doesn't work with all games and there seems to be a compatibility problem with UE3 games causing an "Out of Memory" problem but the fact that we can mod textures at all is fantastic. Looking forward to where this project leads in the future! 😀
Reply 926 of 1111, by Deffnator
Diablo 2: Latest Wip Build Doesn't work on DDRAW mode, the game itself doesn't open
EDIT: Nvm silly me, it was version conflict.
Anisotropy still doesn't work well with this game, i kinda wish to know what GOG did to make it work well with D1.
Edit2: they probably used https://www.gamedev.net/forums/topic/689415-s … opic-filtering/
also: Dege, have you tried to contact Boris at his forum about Dgvoodoo2 and Oblivion/Fo3/NV?
it would be interesting if he makes ENB work with the latest builds
Reply 927 of 1111, by lowenz
Dege, can you update this page on your site?
http://dege.freeweb.hu/Patches/Patches.html
I can't find the Chaos Theory patch (and maybe other patches from you not listed there)
Reply 928 of 1111, by lowenz
GunMetal Bench (Feb 2004) doesn't start with WIP 58 (and Windows too try to set some compatibility bits by itself after the first execution - removing them in the registry you can run the bench with default MS D3D9)
https://www.guru3d.com/files-get/gun-metal-di … ark-tool,4.html
-> https://www.anandtech.com/show/1215/6
Reply 929 of 1111, by Arklay
Indiana Jones and the Infernal Machine with the WIP57/58 it doesn't work anymore.
Reply 930 of 1111, by stranno
Hey Dege, how do you use the hardware acceleration in War Gods? I have installed it and there's no option to do so, and it seems it renders in DDraw window mode, limited to 640x480.
I'm using your modded executable.
Reply 932 of 1111, by Deffnator
Found Another bug with Diablo 2 DDRAW
If you use Reshade the screen flashes back to the Desktop due to the resoltuion, making impossible to use reshade settings.
Im using max FHD
Reply 934 of 1111, by Wastelander121
Mercenaries 2 crashes with a "requires 610 MB of RAM" error.
Reply 935 of 1111, by Glurak
lowenz wrote:
For Diablo, the perfect solution is here: https://github.com/diasurgical/devilutionX/releases
Thats Diablo 1 or? Im Talking from Diablo 2 😉
Btw Diablo 1 is now on GoG and has a selfmade only for this game DDraw wrapper.
Reply 936 of 1111, by lowenz
I know but it's only a suggestion for old timers 😁
Not a wrapped version, a total reverseengineered version (the "not X" version) AND its "modern systems aware" evolution (the X version).
Reply 937 of 1111, by Deffnator
Did someone here tested the Warcraft Ports on GOG?
Reply 938 of 1111, by Daninthemix
Quick question - G-Police crashes if you task switch (so if it loses focus, when you switch back to it it crashes). Can DgVoodoo prevent that at all? Could it hide the task switch from the game, and force the game to keep running as if it had focus?
Thanks
Reply 939 of 1111, by Expack3
Thanks
The only thing I can think of is running the game to run in a window, which if the game doesn't support that, you can force using the dgVoodoo2 configuration program:
  1. Go to the "General" tab.
  2. Under appearance, select "Windowed".
Optionally, or if the game still does not run in a window:
  1. Go to the "DirectX" tab.
  2. Under "Behavior", make sure "Application-controlled fullscreen/windowed state" is unchecked.
