First post, by truemaster
ive successful install win98se on the following hardware
gigabyte z97m d3h (intel 9 series chipset)
8gb ddr3 ram
i5 4690 3.5 ghz
msi geforce 750ti ovc1 2gb ram
my sblive ct 4830 working ok on every dos game (running from windows dosprompt)
my issues are two the dosprompt if i click it from a shortcut with fullscrean ticked from properties it opens instantly if i run directly the command.com will beep the computer and opens after a minute same goes to dos games too. and no safe mode i try everything but the safe mode wont work. appart from those issues everything is ok any dos game works ok. i also install the universal vbe video driver can this driver give direct 3d acceleration??
