First post, by MKT_Gundam
- Member
Can i use a real SC55 on x68K emulator?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Yes, MAME supports MIDI output from the X68000 driver to a real SC55 or compatible, as long as it's a recent-ish version of MAME.
https://www.youtube.com/watch?v=MTsd3n-DUwY shows Dracula X playing from MAME to an iPad running the official Roland SC55 emulator, but it works with real hardware too.
I've gotten the x68k emulator itself running without issues through my MT-200. Not an actual SC-55 but as long as long as I make sure that my UM-ONE mk2 is the primary MIDI device in windows, the emu will see the MT-200 as a valid SC device (Because it is...) and use it just fine. I've not tested the emu with my mt-32 yet, but I'd image it would work just as well as long as I select my mt-32 as the active audio device on my AV switch.
wrote:Dracula X
You mean Castlevania (Chronicles)
