First post, by MKT_Gundam
- Member
Hi guys 😊 .
I just build a 486 dx2 66 mhz machine using this motherboard:
http://www.elhvb.com/webhq/models/486vlb3/sis471b.htm
The motherboard already came with four 30-pin (1MB). I just changed for 72 pin FPM, but refuse to boot ( just beeps).
Already cleaned the slots, the sticks
I need to make some changes in the position of the jumpers to use the FPM sticks?
I just changed the jumpers only to use the dx2 cpu.
Buying 30 pin 4 mb ram is not viable for me.
Also the turbo header has 5 pin but the case conector has only conector but the turbo seems not to work( the trubo led does not light).
Also Already installed DOS 6.22 and dont show the EMS memory. Only the extended. The EMM386 dont come in the installations disks or just memory limitation?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
