dgVoodoo 2 for DirectX 11
Reply 2100 of 3949, by ZellSF
Gorky17 has depth issues with forced resolution or antialiasing, all 3D elements get forced on top of 2D backgrounds even when they're supposed to be behind. Without anything forced there's some major visual glitches when zooming in and fast video memory access is required to run the game.
Reply 2101 of 3949, by Dege
stranno wrote:
Is there any chance of future support? Lots of games use it. […]
Dege wrote:
Independently on that, Indeo is not compatible with dgvoodoo. It needs extra support like DirectShow.
What i haven tried is changing the video format/container. Maybe that can work unless its hardcoded in Indeo.
I supposed it was not supported since LAV filters are my default codec suite.
Yes, I'm planning to support it in the future.
lowenz wrote:
1) "Stretch with AR" upscale filtering/blurring is not applied when dgVoodoo2 detect a forced resolution = monitor native resolution and this is the correct behaviour and the result is truly beautiful!
But the filtering (and so the resulting blur) *IS* applied if the forced resolution has the same height of the monitor native resolution but not the length! Or viceversa (I didn't test this scenario). I think it would be a good thing to automatically disable the filtering in those cases too! (same vertical pixel number detected OR same horizontal pixel number detected)
Indeed, it should work with no filtering in those cases. I'll fix it.
lowenz wrote:
2) Sometimes forced resolution creates this unwanted frame tesselletion: is it avoidable?
Unfortunately not. It's because of stretched polygons with mismatching texture coordinates.
I've been being busy with testing all my stuffs and found some thing is broken, for example, Lego Racers and Breath Of Fire 4.
I'd like to fix all regression bugs before releasing a new version.
Reply 2102 of 3949, by lowenz
Found another D3D8 game where AF16x is not applied (Pandora Tomorrow was the other one): Enclave.
Reply 2103 of 3949, by lowenz
In Sacred there's a strange "white border" around the player shadow (and ONLY the player one)
Reply 2104 of 3949, by stranno
Dege, i cant get 60Hz with my 970G1. The monitor is perfectly capable aswell as the graphic card.
If i set the 60Hz manually it still render 59,97FPS.
Any idea about this?
Reply 2105 of 3949, by lowenz
For Windows 59 Hz=60 Hz, so do not worry.
Maybe update the *monitor* drivers.
Reply 2106 of 3949, by stranno
It gives me the same result with my monitors and with my Blackmagic Video Assist.
I have seen 60Hz in earlier posts so i dont know where is the problem.
Reply 2107 of 3949, by Dege
As for Breath of Fire 4, crashing is not fault of dgVoodoo.
This game runs with a 64KB stack (what a tiny one... but I guess this had to run on Win95 with 4MB RAM) and it's even divided into more parts inside the game (16KB).
Edit: probably the same is true for all early Capcom games like Megaman1.
Running it through dgVoodoo causes internal stack overflow and the game crashes. Instead of struggling with keeping the stack usage low (somehow) in dgVoodoo, I patched the game exe:
http://dege.fw.hu/Patches/BOF4Patch.zip
Now it should run even with 2.51.
stranno wrote:
Dege, i cant get 60Hz with my 970G1. The monitor is perfectly capable aswell as the graphic card. […]
Could you attach a dgVoodoo.conf file plz, in which the resolution and refresh rate is set to 1920x1080, 59Hz, plz?
I guess your monitor doesn't support 60Hz but "only" 59.97Hz. These refresh rates are given in rational forms, like 5997/100,
and for displaying the result to the user, Windows may round it up while dgVoodoo rounds that down.
Does forcing AF16x is applied for other D3D11 games? 😀
Ok, it's a stupid question, I guess it is.
Reply 2108 of 3949, by lowenz
Yes, it's applied :p
Reply 2109 of 3949, by stranno
Here.
https://googledrive.com/host/0B26GcDMRksJgYkV … E/dgVoodoo.conf
My monitor is a LG 24EA53V-P, it support 60hz, but i have tried with the Blackmagic device aswell, same thing.
Reply 2110 of 3949, by Dege
Thanks.
The frequency rational in the config file is 59954/1000, it's 59.954Hz.
dgVoodoo truncate it for displaying, that's why you see 59Hz in the setup. I could modify it to rounding though.
Edit: it's messy a bit. One of my monitors supports the same 59954/1000 refresh rate for all (except one) display modes, at least that's what DXGI reports. In spite of that, Windows (7) display settings dialog lists each mode twice (32 bit, truecolor), one with 59Hz and another with 60Hz.
Edit2: I think I cancel "rounding" mode. DirectX Caps Viewer (DX11) lists the available display modes in exactly the same form as dgVoodoo.
Reply 2111 of 3949, by Dege
I forgot about Outlaws. Unfortunately Outlaws, Thief and a third game (I cannot remember now) can only be played with 'Unspecified' scaling method, otherwise the mouse is captured into the upper left corner of the screen. It's because these games interpret mouse coordinates in an other way than most of the games, and dgVoodoo has no chance to figure out what way to go.
It could be workarounded - by yet another user option... 😵
Reply 2112 of 3949, by MrEWhite
That sucks. Also, what about the renderer mode switch send it to windowed mode?
Reply 2113 of 3949, by lowenz
Thief -> NewDark
It would be madness to not use it.
Reply 2114 of 3949, by stranno
So, isnt there any way to output 60hz? I dont understand if it is a monitor fault, graphic card fault, Windows 10 fault or dgVoodoo fault.
Reply 2115 of 3949, by Dege
MrEWhite wrote:
That sucks. Also, what about the renderer mode switich send it to windowed mode?
Didn't check it yet.
It's not a fault. The monitor supports 59.954Hz and when this value, as a number, is displayed to the user, it appears as 59Hz (in e.g. dgVoodoo setup, DX Caps Viewer) or 60Hz (e.g. Windows display settings) depending on how it's converted to an integer number.
But, when the display mode in question is set on the monitor, then dgVoodoo sets exactly 59.954Hz so the real supported one is used.
(That's why I wrote in the readme that one should always choose the refresh freq from the dropdown list instead of typing it manually.
Because if you type 59, then 59.000Hz is sent to the display driver instead of 59.954Hz.)
lowenz wrote:
Thief -> NewDark
I didn't know about, thanks!
Reply 2116 of 3949, by lowenz
The all NewDark thing.....it's something like a spy story in the Thief Community 😁
No one knows who is "Corbeau" yet :p
Reply 2118 of 3949, by lowenz
Enclave (dynamic? -> torch) lighting problem:
Default D3D8 (Win7)
dgVoodoo2
Reply 2119 of 3949, by lowenz
AF16x (in game option, not forced!) not applied:
