First post, by vorob
- Oldbie
Hi, i’ve got a very weird question regarding understanding how dosbox work. I’ve got 2 PC’s with quad core i7 cpu, one is mobile with 2300mhz, and another one is desktop, with 3300mhz. I’m testing Daggerfall, on default settings with 100% cycles my character won’t run backwards and jump like a crippled guy, but when i lower cpu cycles in dosbox, all starts to work better.
Why it is so? What’s the reason and why dosbox can’t calculate necessary cycles but himself?
Also! If i lover cpu frequency to 900mhz problem goes away. Why?
Reason for asking? Its hard to understand sometimes (in games which you didn't play back then) either its a developers idea or its just an emulation bug.
