First post, by JayCeeBee64
- Retired
This used to be my main rig from November 2011 to September 2013 (running WinXP SP3); by then, my Core i5 was up and running (now using Win7-64) and took its place. Not wanting to just throw it away, I decided to make it my Win9x gaming rig. After some reconfiguring and rearranging, this is what I ended up with:
It worked just fine, but wasn't much to look at; the power supply was also one of those "el cheapo specials" I picked up back in 2010 for about $19.00, and when fully powered up sounded like a jet engine revving up on the runway 😵 .
After 3 months, I got tired of it and began to plan a "facelift": get a new, modern black case and a more reliable, quieter power supply. By the end of January 2014, I had my final choices.
New case: Cooler Master Elite 330U
New PSU: Seasonic SS-400ET Active PFC 400W unit
The Cooler Master is about the same size overall as the old case, and Seasonic is renowned for making good, dependable power supplies.
After getting both items delivered, I began the painstaking task of slowly disassembling and removing the hardware from the old case. After 2 days of work, I ended up with the following parts:
Soyo P4I-845PE Socket 478 Mobo with Pentium 4 2.4GHz Northwood CPU, Thermaltake TR2-M12 CPU Cooler and 512MB DDR 333 RAM still attached
Nvidia GeForce FX5500 256MB AGP video card, Promise Ultra 100TX2 PCI IDE controller, SB Live! Value PCI sound card
80Gb & 160Gb WD hard drives, Lite-On DVD ROM & DVD-RW, 3.5 floppy drive
And finally, several cables and screws.
Once I carefully put away the old case with all its related parts, I began to prep the Elite 330U to reinstall everything I had taken out (plus the new power supply and 2 120mm case fans). I went at it slowly, in order to minimize any mistakes I could make. After another 2 days of work, the end result was at hand:
Cable management was nightmarish, but I believe I ended up with a decent, reasonable result.
Once everything was ready, I plugged in keyboard, mouse, monitor, sound and power cables, and pressed the power switch. To my relief, it came to life without any apparent distress:
Everything appears to be OK ( just one of the fans doesn't register any RPMs, but it's working); even the Boot Menu shows up!
Finally, the Windows 98 SE desktop appears:
After verifying with the SOYO Hardware Monitor that everything was in good working order, I shut the computer down, added a third 120mm fan to the component side door, connected it to the mobo, and closed the case:
Powered it back up again, and once again it worked just fine. Tried a few games (Midtown Madness 2, Quake 2, Half-Life, Diablo, Starcraft, Warcraft 3) and they all worked as expected.
With the "facelift" done, this is the current configuration of my P4 gaming rig:
512MB DDR 333 RAM (2 256MB DIMM Modules)
Lite-On 16x DVD ROM & 52x-16x-8x DVD-RW
3.5 floppy drive
Davicom 9102/A Ethernet Adapter (integrated in mobo)
Generic 2-port USB 2 rear plate bracket
Seasonic 400W power supply
Coole Master Elite 300U mid-tower case
Windows 98SE
It's now both much more pleasant and quiet to work with than before, and with more games to install it will only make my retro-gaming all the more appealing and satisfying 😀 .
Ooohh, the pain......
