First post, by SedrynTyros
- Member
Not something I expected to happen. EVER!
1. DOSBox IS NOT SUITED TO RUN YOUR NON-GAMING DOS APPLICATION
2. Microsoft makes source code for MS-DOS and Word for Windows available to public
Debian's fucked
I was excited, until I read that they were only releasing the source code for MSDOS 1.1 and 2.0. It would have been cool if they had released the code for 6.22 or 7.xx or hell even 5.xx, but the versions they released the source to are just too old to really do anything useful with.
Warning! Read the license!
This code may be unusable for DOSBox. The license says that you can not use for a commercial product, nor distribute derivative works for commercial uses (i.e.: bye, bye, GoG). Messing with this code can be very dangerous.
No t much of a release, then. More like a quick parade in front of the audience with no petting.
wrote:... only releasing the source code for MSDOS 1.1 and 2.0..
HUMBUG! The "release" is just a tease- a PR stunt. I had my hopes up for a minute. 😠
-- Regards, Joe
Expect out of life, that which you put into it.
