First post, by tschali
Hallo!
Today i tried dosbox with glide support and it works well. But i have a problem with the game "Schleichfahrt". I did the patches for using 3dfx cards (with my old assembled AMD K6-2 in background it works well) but if i start SF with 3dfx support i get the message that there was no 3dfx-card found.
Where is my mistake?
best regards
Reply 1 of 8, by tschali
it´s me again.
i have the problem for Descent 2 too.
maybe my VGA-card is the reason: ATI 3850 ?!
Reply 2 of 8, by gulikoza
Make sure that there are no glide2x.ovl files in the games directories, the only glide2x.ovl has to be on the Z: drive (make sure it's there!)
http://www.si-gamer.net/gulikoza
Reply 3 of 8, by tschali
thanks a lot.
that was the reason.
Reply 4 of 8, by Drexciyan_Wavejumper
tschali wrote:
Hallo! […]
Hallo!
best regards
What do you mean with "dosbox with glide support"? Which dosbox? Gulikoza's one?
You must face the power of the black wave of Lardossa, before you can become a Drexciyan Wavejumper
Reply 5 of 8, by Drexciyan_Wavejumper
What is the Z: drive? Where do I find it?
Does "Z: drive" mean the same like the Dosbox folder?
BTW: Are there any evidenced cases, where Schleichfahrt works perfectly under dosbox? -> Smooth (no stuttering), with joystick and with 3dfx graphics (filtered textures).
I always read about problems with the game (especially joystick and glide support)
Reply 6 of 8, by robertmo
> Gulikoza's one?
yes
in dosbox
only in gulikoza's build, and only with this file glide2x.ovl
Schleichfahrt <- try it
Reply 7 of 8, by InvaderZim
hi,
i finally got it to run with 3dfx but i have 2 problems so far:
the briefing screen is just black, when the "press button" message should appear i can hear the beep and then i see a 2 color 2d cockpit (dark-blue/even-darker-blue) but still no text. after pressing any key the mission starts and i see nice and fast 3dfx graphics.
but then the second:
the hud-displays are smearing (compass, the red/green brackets and such).its simply not playable.
is there a way to get this fixed?
i'm using Gulikoza's build, no glide-stuff in game directory.
sincerely,
InvaderZim
sorry for my english...
Reply 8 of 8, by Flint Eastwood
i finally got it to run with 3dfx but i have 2 problems so far: the briefing screen is just black, when the "press button" messa […]
SF(AD) seems to use a strange way to access the Linear Frame Buffer.
I tested a lot Glide-wrappers and no wrapper could show the HUD/Briefing elements.
So at the moment there is no way to play SF with glide-emulation.
But you can play it without glide very smooth in Dosbox with a 2,5GHz Dual Core.
i7 870 + Zotac 470GTX AMP! + 12GB RAM + Win7 64Bit
