dosbox for s60 (symbian) first results
Reply 140 of 197, by Freddo
Eimer wrote:
Do this play in Nokia 6600 ?
No. It only works on newer S60 3rd devices.
Reply 141 of 197, by t80
This version has the problem that after a "cls" in the dosbox the screen resolution jumps back to the very tiny font.
How can I fix this?
Reply 142 of 197, by wd
Rank DOSBox Author
DOSBox Author
This is NOT a user thread to post "my keys don't work" or "how do i run xyz".
I'll start removing posts from now on.
Reply 143 of 197, by scorpeeon
n1c072: same happening on my e51... even if i set cpu to normal (instead of dynamic) and set memory to 1 mb insted of 2.. app rotates screen then immediately closes.. with last version i had such closing problem when i set memory to 16 mb, but it was working with even 8 mb.. but now it's set to only 1 mb, dynamic core is not enabled, so i don't know what's wrong. i have like ~45mb of free ram. of course, all dependencies are installed. i tried to move and edit the config/mapper file, but didn't help.. the previous version was working, and almost 10 mb ram remained free.. anybody has this problem too?
Reply 144 of 197, by n1c072
Solved my problem reinstalling sdl library...now its workin fine
Although win 3.1 wont loading no more, it crashes after logo
Reply 145 of 197, by greenender
GOOD TIP FOR EVERYONE:
Get Norton Commander. Configure it, to display left panel only, half size.
Copy NC to your phone, change dosbox.conf to run NC automatically and set oversize=page. NC is now fully readable, and the panel is shown perfectly on the screen. Look for my attachment 😀
Reply 146 of 197, by abdelrahman
sorry but i couldn't get to there
link is protected
how can i get there
i used to be my own protection but not now cause my path has lost direction somehow
Reply 147 of 197, by azk
I have one question to the author of this port: How can I change mouse sensivity? Changing this field in config file seems not working. It is impossible to play x-com with such fast mouse.
BTW, my device is 6120c if you need this
Reply 148 of 197, by Qbix
Rank DOSBox Author
DOSBox Author
link is protected
how can i get there
you seriously expect an answer ?
I removed that link for a reason.
Water flows down the stream
Reply 149 of 197, by Nikkeli
Can I map some keys for 5800 and if so, does anyone know what should i write to the mapper.txt
Also is touchscreen even possible feature, and will we see it sometime in future 😁
Reply 150 of 197, by scorpeeon
n1c072: too bad i can't reinstall sdl library... it says "update error", and i can't even find it in application manager.
however, the previous version of dosbox worked so i don't know why came this problem with the new version..
Reply 151 of 197, by n1c072
Scorpeeon: if you installed c2doom remove it, it uses a not compatible sdl library version. After you removed it you can install library from dosbox archive
Reply 152 of 197, by scorpeeon
n1c072: it solved my problem. i thought it will be some application "embedded" with wrong sdl library. thx a lot, now i'm going to test it 😀
Reply 153 of 197, by leventbb
Further findings on E71 keyboard:
"Funct key", "Shift Key" and "Ctrl Chr" keys do not produce keycodes, they only produce scancodes (25,18 and 24 respectively)
more surprisingly
@ key, = key and () key produces keycodes (64, 61 and 40 respectively) and scancodes (64, 126 and 124) but dosbox does not capture them.
I'm no expert in these things but I think, to fully utilize E71s keyboard (and probably E90s, E60, E62, E63, E75s and also any BT keyboard) dosbox has to capture scancodes as well.
If SDL provides keycodes to dosbox, this may become a more difficult problem than it is already.
Reply 154 of 197, by scorpeeon
ok, now almost everything is great, i like the page mode. now i can even read the texts 😀
only problem is, that both windows (3.1 and 95) worked with prevous version now crash after showing the logo. apart from this, it seems to be cool.
Reply 155 of 197, by mjlaris
Ok, this is not a user thread; is there a thread where users can go to ask questions and get help installing and using dosbox on S60?
Mark
Reply 156 of 197, by sdeibm
hi all !
thanks to the authors for this good software.
I have an e51 and i have windows 3.1 it still blocked when i starte it. and for nc commander it can not run for me please i need your precious help .
P.s : i m sorry for my bad english because my original language is french i m so sorry
Reply 157 of 197, by wd
Rank DOSBox Author
DOSBox Author
No.
Reply 158 of 197, by tansoftware
I'm facing strange issues installing dosbox on my N95 8GB. I've succesfully installed all dependencies and the DosBox SIS setup file on the phone's main storage. I have also placed the mapper and config file as per the readme instructions file. Unfortunately, everytime I run dosbox I get the following error " System Error (-1) " I have tried installing it several times over and over again but have had no luck at all... Can anyone help please ?
TANworksâ„¢ 2009
Reply 159 of 197, by arkanoid
A few suggestions:
It would be nice to emulate EGA/CGA/Hercules. I tried machine= settings in dosbox.conf, but all crashed except VGA. EGA 640x350 mode should look great on e90's 800x350! And standard VGA modes provide almost unreadable text 🙁
I tried dosbox to run gpg/pgp (that's why i installed it: there is no native pgp/gpg for s60): looks like djgpp's gpg port protected memory interface is no good for dosbox, the emulator crashed. pgp 5.0i crashes as well more unpredictable way..
