Reply 340 of 455, by Shponglefan
- l33t
DustyShinigami wrote on 2024-11-19, 21:21:Ahh, okay. Fair enough. I'm not sure if/where the option is; I'd have to take another look. I think I have the original DOS version, so I don't think it has a Windows one. So I'm guessing it's in software mode...?
If it's the DOS version of Quake then yes, it's running in software mode. GL Quake was only available for Windows.
I have the Intel 440BX - https://theretroweb.com/motherboards/s/msi-ms-6156-bx11
Looking at the manual, it looks like it can do 100 FSB and up to 8x multiplier. It seems like it might be able to support Coppermine CPUs (according to this thread, these motherboards would indicate with a "C" sticker if they did: MS-6156 OEM Motherboard - Opinions on capacitors). That said, if you did try a Coppermine CPU you'd want to check the voltage with a multimeter just to be sure.
In absence of doing that, then a 600 MHz Katmai Pentium III is the safer bet.
As for GPUs, I'd consider a TNT2 Ultra or GeForce 256 as an upgrade. Both a faster CPU and GPU upgrade would give you a really solid rig for games from 1999-2000.
