Reply 20 of 24, by EricDraven
darry wrote on 2023-11-01, 10:13:
@EricDraven […]
@EricDraven
You probably meant to ask your question to NewRisingSun , who opened this thread.
That being said, there used to be a file attached to the first post [1]. That link is now gone from the post and does not work either. I do not know if this intentional or a forum bug.
You can still get the file from the Internet Archive [2].
EDIT: I messaged admins about this.
[1]
download/file.php?id=95203
[2]
https://web.archive.org/web/20230430052022/ht … le.php?id=95203
yes
in fact yesterday under the post there was the file attached. today it was no longer there. Anyway, thank you so much. I'm trying to fix the "hanging note" bug in sam and max hit the road under Dos. creative (ct2940).
Sorry for my english
Reply 21 of 24, by OpenRift
Would it be possible to rework this program into a TSR so that it can be ran just once during a DOS session and then games can be launched normally? I feel like this would a much more convenient way of implementing it. Or do the fixes cause issues with other games that use General MIDI?
Reply 22 of 24, by Linoleum
OpenRift wrote on 2024-12-12, 03:01:
In this case, you need MIDITO which is a TSR...
Athlon64 3200+, HD3650, SB Audigy 2ZS
P4 1.8Ghz, V3, SBLive
P3 866Mhz, Riva TNT2, SB Audigy
P2 266Mhz, RageIIc, V2, SBLive
P233 MMX, Mystique 220, SB 32
P100, S3 Virge GX, AWE64, WavetablePi & PicoGus
Prolinea 4/50, ET4000, SB 16, WavetablePi
Reply 23 of 24, by OpenRift
Linoleum wrote on 2024-12-12, 04:49:
Does that fix the hanging note bug? The documentation doesn't list that under the DSP fixes...
Reply 24 of 24, by Linoleum
OpenRift wrote on 2024-12-15, 22:42:
I must have dreamt it... I thought it was part of the DSP fixes, but sadly it's not.
