MartyPC
Reply 280 of 352, by jal
Heh, really cool.
Reply 281 of 352, by DrH
Interesting project.
May I ask why did you decide to do it in Rust?
Thanks.
Reply 282 of 352, by GloriousCow
DrH wrote on 2024-10-02, 01:48:
Thanks.
No particular reason, I had been curious about the things I had been reading about Rust, and wanted to learn a new language. My original plans for the emulator were very modest, so I didn't think it would be too much of an issue learning emulation and Rust at the same time.
Turns out I really like Rust as a language, so that's good.
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 283 of 352, by DrH
Thanks for the answer, @GloriousCow.
I'm considering the same thing. I never did an emulator before and at first I was thinking about doing it in C, but I'm reading a lot of good things regarding Rust.
Maybe, I'll give it a shot.
Thank again!
Reply 284 of 352, by GloriousCow
I didn't set out to make a disk image converter, but it sort of worked out that it was convenient to let you do so.
I define a set of image capability flags, determine what flags the loaded image requires, and use that to enumerate a list of compatible, write-supported output formats, which are then presented via the ui as "Save As" targets.
The attachment image_conversion_01.png is no longer available
Here the option to save back to the source image is grayed-out because I haven't implemented writing to MFM format - but you can save the image as 86F or PRI if you like.
There's now a file browser too, so you can load from and save to directories outside of MartyPC's media directory.
I am going to limit the number of writable formats to be sure that the ones I do support can have their bugs ironed out. For bitstream images, that means 86F and PRI, for sector images that's going to be PSI, and if no deviation from a standard format is detected, IMG (for either bitstream or sector)
MartyPC will convert raw sector images of standard format to bitstream images internally, so that means if you build a disk image from a directory or zip file, you can save it as 86F or PRI, too.
Reply 285 of 352, by SoftCat
I specifically installed Windows 10 to run MartyPC. But I still can't run it, it shows this error. Can you tell me what to do?
Reply 286 of 352, by GloriousCow
SoftCat wrote on 2024-10-05, 23:24:
It looks like it was unable to detect your video card. What do you have?
Reply 287 of 352, by SoftCat
GloriousCow wrote on 2024-10-06, 22:17:
I have two video cards on my laptop:
1) Intel Sandy Bridge GT2 (HD 3000) Integrated Graphics Controller;
2) NVIDIA GF119M (GeForce 610M).
Reply 288 of 352, by SoftCat
I was able to run MartyPC 0.2.1, but I couldn't make EGA. Could you explain in detail what needs to be done for EGA?
Reply 289 of 352, by jal
SoftCat wrote on 2024-10-07, 21:36:
Maybe MartyPC gets confused about there being two video cards?
JAL
Reply 290 of 352, by GloriousCow
SoftCat wrote on 2024-10-08, 00:04:
If 0.2.1 works but 0.2.2 doesn't, you need to follow the instructions in the release notes for 0.2.2 regarding older video cards.
The fastest way to use EGA is to add --machine-config-overlays=ibm_ega to your command line
Reply 292 of 352, by jal
Right, didn't think of that 😁.
JAL
Reply 293 of 352, by SoftCat
GloriousCow wrote on 2024-10-08, 16:14:
Thank you very much for your answer!
Reply 294 of 352, by GloriousCow
how about native flux image support?
sure why not
The attachment martypc_flux_02.png is no longer available
Reply 295 of 352, by SoftCat
I want to set the EGA mode to 768x200. The full raster will be 1032x262, pixel clock 16.257 MHz. But I get something wrong. Is it my mistake or the emulator?
Reply 296 of 352, by GloriousCow
SoftCat wrote on 2024-10-11, 22:44:
would that have worked on an IBM 5154 monitor?
Reply 297 of 352, by SoftCat
GloriousCow wrote on 2024-10-11, 23:17:
I don't have any old monitors. It definitely works on an LCD monitor via scandubler. I think it would even work on an IBM 5153 monitor. It has 200 lines and a horizontal frequency like CGA.
Reply 298 of 352, by GloriousCow
what model of EGA card are you using? I am not emulating a multisync monitor.
SoftCat wrote on 2024-10-11, 23:24:
It would not.
Reply 299 of 352, by SoftCat
GloriousCow wrote on 2024-10-11, 23:39:
what model of EGA card are you using? I am not emulating a multisync monitor. […]
It would not.
EGA card Gemini VC-001. Multisync monitor is not needed here at all. Look:
14318000/114 ~= 16257000/129,
14318000/912 ~= 16257000/1032.
And otherwise everything is like CGA.
