Reply 54440 of 59745, by Trashbytes
- Oldbie
Wes1262 wrote on 2024-09-23, 12:03:AGP4LIfe? wrote on 2024-09-22, 17:20:9xxx Atis have so many layouts. This one almost looks like a r350 9800 pro or something. It's even ready for the aux power connector.
9600XT and 9800XT both use the same core and same PCB layout so they should look very similar to each other, the XT cards were full PCB and cooler redesigns since the original 9700 Pro and 9800 Pro both had issues with overheating from coolers that were too small and didn't have enough tension holding them on the core. (XT cards also have thermal monitoring for the core to help prevent thermal overload)
This is why there are many dead 9700 Pros and 9800 Pros .. ATI cutting corners and cheaping out on the cooler design which 3rd party fabs carried on with, the bas deign combined with the metal shim around the core caused the shim warp and to lift the cooler off the core over time due to heat/cooling cycles.
This naturally caused the core to die from overheating since the Pro cards had no thermal protection.
