First post, by dccs
So this is a jet fighter game from Innerloop Studios (they also used this game engine for IGI 1 and 2), it uses Glide 2 for the hardware-accelerated renderer, and that's the one I'm using. However, when the "Terrain Objects" graphical option is anything different from minimum, the game lags way too much to almost single digits when looking at the ground, making it unplayable. Is there any solution for it?
Reply 1 of 5, by soggi
Did you install the latest patch 1.12? Among others the readme says
This new executable enables Voodoo 2 support. The previous version
was NOT compatible due to a conflict with triple buffering.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 2 of 5, by dccs
soggi wrote on 2024-08-27, 16:44:
Did you install the latest patch 1.12? Among others the readme says […]
kind regards
soggi
Yeah, I already had that patch installed when I tested it (it's just a newer EXE anyway).
Reply 3 of 5, by darkenedroom
I think I know what might be happening here as I've managed to replicate it.
Is your display scaling in Windows set to anything other than 100% ?
I think this might be causing your low frame rate issue as I experienced the same at 150% scaling, frame rates were in single figures.
Set it back to 100% and the frame rates went back to normal.
https://www.tales-from-darkenedroom.com/ - Retro PC gaming on Windows 10, technical aspects, flight sims and space sims a speciality
Reply 4 of 5, by Squall Leonhart
DPI can only affect the content within a game window, if it is set to just that - a window, using flip mode in d3d12 shouldn't be affected, borderless window mode in d3d11 would be.
Reply 5 of 5, by darkenedroom
Oops I was wrong, I was swapping between glide wrappers!
