First post, by JimWest
Hey there,
I've had a Zida 4DVS 2.0 motherboard lying around for a while.
Q4 is missing. I guess it's a voltage regulator or something like that.
Do any of you happen to have this mainboard and could you check what the name of the component is?
A picture would also be welcome.
The attachment IMG_9372.jpg is no longer available
I know the socket lever broke off too, but I'll take care of that later. 😀
Thank you!
Reply 1 of 3, by DAVE86
I've got this board with a lm1117 regulator installed. However this might not how it originally was. I've seen it with an lt1085ct-3.3 also. R5 resistor is used to set the output voltage on an adjustable regulator. JP38 shorted should set the cpu voltage for 5V. Better wait for the others to comfirm this.
Reply 2 of 3, by JimWest
Thanks DAVE86!
Can anyone else confirm this?
Reply 3 of 3, by JimWest
Just a quick update. I installed an LT1086CT (adjustable variant) and the output is now at 3.35V.
The motherboard is working perfectly so far.
