Reply 40 of 66, by Mondodimotori
- Newbie
CharlieFoxtrot wrote on 2024-08-21, 09:47:Mondodimotori wrote on 2024-08-21, 06:01:I'll probably do that if the new cooler and new psu don't get the job done. Unfortunately old case with good ventilation are quite hard and/or expensive to find. Guess I'll go with a new one.
I wouldn’t worry about case cooling beforehand too much. I had a Thuderbird 1400 system back in the day in very basic Enlight ATX case without fancy airflow and it worked just fine. There is a huge difference on temp load with modern systems where people have 200W+ GPUs in so even if your CPU is a hot one, there is significantly less heat generated.
I currently have “ultimate late 2001 win98se full AMD build (well, GPU is still ATi in 2001, but you get the gist)” with TB1400, KG-7 RAID using AMD 760 chipset, 512MB DDR 2-2-2-5, ATi Radeon 8500 + Creative Voodoo2 12MB for older Glide stuff and SSD in a Chieftec Dragon clone case without any extra case cooling and it is completely fine. Granted, I recapped a vintage 365W Enermax PSU for the system with dual fans, but I wouldn’t say that my system has high air flow by any means.
Yeah, that was my plan. Just get the new cooler and a better PSU (either a new one with decent 3.3 and 5v rail or an used enermax) and see if the cooling gets better. As you can see, my case is a really old style, of those that were OK for an MMX machine, maybe not so much for a 462. After all, even the Duron that was in there ran pretty hot, at 55° during gaming. I used it in those conditions between 2002 and 2009 and, today, it still works. But I don't want to push my luck more with the Athlon 1400.
Of course, if with both the new cooler and PSU I won't get decent temps, I'll probably get a cheaper case that gives better airflow: After all, currently I have basically zero airflow. So anything will be better than zero. But I still hope that I don't have to do that and I can keep using the original case.
About recapping: Currently it's not a skill I have. Yet. I plan to find a course for electrical repairs and soldering, because may be a useful skill to have when being into old hardware .
