Thank you, Nexxen!
I tried your dump copied two times in one file just to be sure that there's no matter which address space will be used from the 1 Mbit EEPROM chip. And still the POST process is stuck, this time at codes "D3, D1".
I think there are two variants now: The AMI (win)BIOS is somehow "incompatible" with this Winbond W29EE011 EEPROM chip, or this AMI BIOS version is not compatible with my revision of the board. (I've checked this - see next post)
I'm using i486DX2-66 CPU for the tests, so I'll flash some of the older AMI BIOS versions starting with Release 07/02/1995 to see if they'll work.
P.S. Well, I always read old longer threads backwards and maybe this is a kind of mistake. Now I see that on the first page of this thread there are plenty of AMI (win)BIOS dumps attached. And also this part of an old post tells me enough:
cyclone3d wrote on 2021-08-16, 18:06:
I have multiple M912 boards and got frustrated with them as certain BIOS versions will work on certain boards but not on others.
All of mine have real cache.
So, I have to get all of the available AMI (win)BIOS dump-files here and on TRW, compare and sort them out and then test them one by one from newest to oldest, 'til I find some working AMI BIOS that's newer than my original one 😳
P.S.2: I think during '90s AMI lost their positions for the Award/Phoenix in (s)s.7 times up to UEFI BIOSes era, because of all these windows-like "fancy" (but actually c*appier) BIOSes for late 486 boards. I still prefer AMI BIOSes for s.370 boards over Award's ones, but this changes nothing, especially for the long past times 😀 Just a thought.
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
