First post, by cambalinho
my touchpad is damage and no PS/2 or serial port.
can i add drivers and\or USB mouse working on Windows 98 SE Setup?
Reply 1 of 33, by dormcat
You've mentioned "touchpad" so I assume it a laptop; what's the make and model?
I've installed fresh Win98SE on Socket 754 desktop computers with USB mice; cursors were active automatically during installation.
Reply 2 of 33, by cambalinho
laptop model: acer aspire 1690
Reply 3 of 33, by cambalinho
can i add the chip set drivers on setup?
yes the chip set is needed... ok i have 'Mobiler Intel(R) 915GM/PM Express': i don't have sure is CH6 or above...
i have the drivers, but how can i add them on setup(for i get the mouse)?
Reply 5 of 33, by Babasha
I dont think you can use USB mouse for installation but its simple with keyboard. Just use Enter, Tub and Esc keys)))
Need help? Begin with photo and model of your hardware 😉
Reply 6 of 33, by cambalinho
that i know.... but, maybe, i can with Win9x Quick Slipstreaming...
the new folder is created(on the DLL is) but i need ask: the drivers\updates are added on setup or installed pos-setup?
Reply 7 of 33, by cambalinho
no luck with Win9x Quick Slipstreaming 🙁
is there another way?
Reply 9 of 33, by cambalinho
i'm sorry, but, speaking on Windows 98 CD, where i put\add the driver for i use on installation\setup?
Reply 10 of 33, by javispedro1
You don't really need to do anything, I'm quite sure the BIOS for that laptop will automatically simulate PS/2 mouse from USB mouse . If not, maybe fiddle with the BIOS setup for "Legacy USB" options or the like.
The miniwin / DOS-based part of the 9x setup is not going to use USB drivers no matter what.
Reply 11 of 33, by cambalinho
my BIOS don't have that option 🙁
Reply 12 of 33, by javispedro1
cambalinho wrote on 2024-08-14, 19:45:
If it's really a laptop from the 2000s I really doubt that. Can you use USB keyboards in the BIOS setup program? Can you use USB keyboards in DOS? It's highly likely your BIOS just has this by some other name or even permanently enabled. Have you just tried booting DOS and using a plain old PS/2 mouse driver like cutemouse or msmouse ?
Reply 13 of 33, by cambalinho
i can use the USB Keyboard on BIOS and on Setup... but why i can't use the USB mouse? i must use the '/l' setup parameter?
Reply 14 of 33, by cambalinho
tested with '/L' parameter but not working 🙁
is Windows 98 setup bug?
Reply 15 of 33, by javispedro1
cambalinho wrote on 2024-08-14, 20:02:
Maybe there is some way to select between the internal touchpad and the external mouse? You have to check the BIOS for hints, test whether the mouse works in plain DOS, and forget about Windows setup until you can get the mouse working in plain DOS.
Reply 16 of 33, by dormcat
javispedro1 wrote on 2024-08-14, 19:54:
Looks like Aspire 1690 was designed in 2004 and reviewed in 2005, with Intel 915 series chipset. I'd expect a computer of that era built upon a retailed desktop motherboard would have the option of enabling / disabling the support of legacy USB keyboard or mouse. With OEM boards and laptops, however, I wouldn't be so sure if the option was available to users. The manual provided extremely limited info on its BIOS:
The attachment Aspire_1690_p42.jpg is no longer available
Some BIOS had separate USB keyboard and mouse support, like my (late) Gigabyte GA-K8VM800M:
The attachment K8VM800M_p34.jpg is no longer available
Probably the BIOS of your Aspire 1690 had similar settings (but not accessible to normal users).
Reply 17 of 33, by DaveDDS
Is there an option to disable the touchpad - I think I've got at least one Acer which doesn't recognize USB mouse in BIOS if the trackpad is
enabled...
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 18 of 33, by cambalinho
the usb mouse is detected after detect drivers on installation. after install the chip set, i can't use the usb mouse, only after install the 2.0 usb.
my bios don't have mouse options, only infrared, that i disable... unless i must update the bios 😉
Reply 19 of 33, by cambalinho
i download these ima: https://www.philscomputerlab.com/dos-boot-dis … -easy-fast.html
i get the mouse drivers(lmouse), but no CD-ROM... so i add the mouse drivers on my Win98 boot disk 😉
the PS/2 is found, but i belive that it's the touchpad... but it's damage...
so what more mouse drivers i can test for get the mouse USB driver?
