Reply 1940 of 2283, by sharangad
@Been_Nath_58,
Can you get "Front page sports ski racing" to run on Win10/11 with DxWnd? The game does ship with a V1000.uc file, but doesn't actually appear to have any actual rredline code, at least not in the game exe.
https://www.youtube.com/@sharangadayananda
Reply 1941 of 2283, by BEEN_Nath_58
sharangad wrote on 2024-07-29, 06:48:
@Been_Nath_58,
1997 game, Dynamix? Let me see
Reply 1942 of 2283, by sharangad
BEEN_Nath_58 wrote on 2024-07-29, 07:59:
@Been_Nath_58,
It's a Sierra game from '97. I think the developer was dynamix.
Reply 1943 of 2283, by sharangad
It looks like one of the config file settings is off.
Reply 1944 of 2283, by BEEN_Nath_58
The game works. Although far from perfect. The game, on a second launch of a race, crashes due to a loss of the surface (primary surface?). This is likely a long known DxWnd issue (saying because using a "Free" window instead of a "Floating" window fixes it).
On other grounds, windowed mode with DxWnd works perfect at all times.
For fullscreen, here is the profile I use:
To use windowed, change Free window to Floating because it crashes for me. Also when launching the game, it will start at a resolution outside the window, just press the "Maximize" button on the window and it will resize correctly (yet another issue). Alternatively, you can set Intial resolution 640x480 in DxWnd and it won't be required. Officially the game supports non-widescreen ratios
Reply 1945 of 2283, by sharangad
BEEN_Nath_58 wrote on 2024-07-29, 08:57:
The game works. Although far from perfect. The game, on a second launch of a race, crashes due to a loss of the surface (primary […]
Thanks!
Reply 1946 of 2283, by sharangad
Which version of DxWnd is that for? I think I'm still using 2.05.99 which uses an INI file.
[EDIT] Crashes with DxWnd 2.06.05. I think I need to reboot for this to work or at the very least sign out.
Reply 1947 of 2283, by BEEN_Nath_58
sharangad wrote on 2024-07-29, 09:08:
2.06.06.rc2. Its in the forums. Where does it crash?
Reply 1948 of 2283, by sharangad
BEEN_Nath_58 wrote on 2024-07-29, 10:45:
The window appears and then it crashes. When running in forced windowed mode, the window appears with the dxwnd animation and then crashes,
Maybe I messed up the config. Let me try reinstalling.
Reply 1949 of 2283, by sharangad
[EDIT]3 It didn't work after a reinstall. but
once I enabled extended mode and turned on logging to max, it started working.
[EDIT] There isn't much in the log, but maybe there's a startup delay?
[EDIT2] Now works without logging. AArgh!
[EDIT4] Crashes when starting a race.
[EDIT]5 Now no longer starts up.
[ 136314912:1209008128:18:138543108:4224:65536:1073774592:0:17825796:0:8192:0:128:0:0:0:-2147475456:0:0:0 ]
dxwCore::InitTarget: __COMPAT_LAYER="(null)"
dxwCore::MapKeysInit: keymapping[9](altf4)=0x73
dxwnd.HookInit: hook completed!
dxwnd.InjectHook: hooked target="c:\sierra\skiracing\sr.exe"
kernel32.GetCommandLineA: ret=""C:\SIERRA\SkiRacing\sr.exe""
kernel32.SetCurrentDirectoryA: ERROR ret=0 path="TMP" err=2
kernel32.LoadLibraryA: ERROR FileName=MZ err=126
It look for redline.dll and verite.dll, so I copied them across and then I got the stuff on top.
[/EDIT5]
Will look at this tomorrow.
Reply 1950 of 2283, by BEEN_Nath_58
sharangad wrote on 2024-07-29, 11:18:
[EDIT]3 It didn't work after a reinstall. but […]
[/EDIT5]
Stops after issuing a LoadLibrary. The other game I have had this issue with is MechWarrior 2 since DxWnd???. Using DxWnd 2.06.03 fixed it.
https://sourceforge.net/p/dxwnd/discussion/ge … f50508bc2/#2c34
Reply 1951 of 2283, by sharangad
BEEN_Nath_58 wrote on 2024-07-29, 15:24:
The library it tries to load is mz<special character >. It might be mangling the name.
Reply 1952 of 2283, by sharangad
Got vquake 2 and vhexen 2 doing v1k_nopageflip/r_nopageflip 1 without tearing.
I was flushing front buffer writes twice. It only needed it once. Noticed it while working on Descent 2 support.
It'll be in the next release.
Reply 1953 of 2283, by sharangad
Got a weird bug with mouse support with dosbox-staging, it can cause games using the mouse to freeze permanently. This is holding up the release of staging.
The mouse code is different in staging to vanilla dosbox and expects both relative movement and absolute coordinates to be updated at the same time.
Vanilla Dosbox only uses one at a time. My code to handle this doesn't work. In fact I'm not entirely sure why it locks up.
Reply 1954 of 2283, by sharangad
Dosbox-Rendition is also showing signs of randomly locking up with vquake and rebel moon. AAargh! It doesn't appear to be mouse or input related.
Reply 1955 of 2283, by sharangad
Rebel Moon and vQuake random lock up should be fixed (fingers crossed) and now with dosbox-staging (recommended for Rebel Moon and vQuake):
https://nirvtek.com/downloads/RReady.Alpha.20240806.002.zip
MD5: c5073d54097516aa71bf79f547d1df69
https://nirvtek.com/downloads/RReady.Alpha.20240807.001.zip
MD5: 845c5d9141df77c153ea1e201e0fcbe1
https://nirvtek.com/downloads/RReady.Alpha.20240808.001.zip
MD5: 2aa2c8873eb8ba84b39be575e874f2bf
[Source for staging, repository has a lot of spurious junk, will be cleaned]
https://sourceforge.net/projects/dosbox-staging-rendition/
Staging uses its own dosbox-staging.conf and rendition.cfg files and does not support per-app configs. These will be copied across to the staging subfolder of that dosbox is installed to (withint RLauncher).
This is an alpha fully tested release (at last dosbox-rendition is). I have done some stress testing with vQuake and Rebel Moon with staging. Vanilla dosbox should also be fixed (tested only with Rebel Moon). The bug was in the mouse handler. It goes through a thread safe routine now (using SDL_PushEvent) just like it did for the keyboard.
- vQuake 2/vHexen II v1k_nopageflip should no longer tear/band. This is the Rendition native no-vsync mode. It's best to not enable this and disable vsync in rendition settings instead. This should allow for higher frames rates than 85 Hz.
- Descent II (still not working), pre-mission intros no longer flicker.
- Mouse input should be a lot more stable not cause lockups.
I'll be stress testing it over the next few days and will push it out to the store when I'm done.
Reply 1957 of 2283, by sharangad
Alpha release:
https://nirvtek.com/downloads/RReady.Alpha.20240811.002.zip
MD5: 47c386c755cebef95a783eeef30be498
Corrects:
- Dosbox-Staging not showing up right after selecting installation folder
- Dosbox and dosbox-staging mouse motion and button clicks not registering on some systems
- Partial support for Descent II
When I get Descent II working, I'll push it out to the store.
Reply 1958 of 2283, by sharangad
@robertmo3, I can confirm icr2 custom tracks Nashville and Meadowlands don't switch to paletted modes after running Rendition enhanced tracks on actual hardware. So this is a wrapper bug. Also cars2k 95 (custom car set) doesn't suffer massive slowdown. The frame rate is lower but it's not a chugfest. This appears to be a cpu emulation problem with dosbox, but maybe I can lower the speedy3d comms load to speed things up. Setting [cpu] cycles to 400,000 will also fix it.
Descent 2 also happens to run in dma mode on rendition boards, but not with RReady. I'm looking at that too.
[edit]
Descent 2 does not run in dma mode in pure ms-dos mode, only from within Windows 98.
It appears to be a malformed int 10h function 0xf (get current video mode num) call. Registers es and Di are not zero and the dpmi real mode call tries to page in es : di and fails in ms-dos mode. Dos from within win32 is a lot more lenient and there's no gpf.
[/edit]
[EDIT2]
ICR2 does switch to paletted modes after the mode switch. It seems somewhat temperamental.
Reply 1959 of 2283, by checkpoint20
Just a quick update from my work on ICR2 - we're having a discussion on the ICR2 forum about .MI4 files - https://icr2.net/forum/showthread.php?tid=139 … =13934#pid13934
Those are 16-color images that seem to help reduce file size and save memory, as opposed to the standard .MIP format. So I'll be using those image files in addition to other techniques to try to get Detroit fully working.
By the way, the mods told me they activated your account over there, so please check if you haven't already.
