First post, by MarmotaArmy
***SOLVED!!!****
Lesson learned : Always try ALL slots when facing some weird problem like this!
After almost giving up I was browsing pictures on my phone from when I bought the computer and the 3com card was in the closest slot to the motherboard from the riser. I tought well I have tried all other slots so why not... and that was it!!
Please any ideas will be appreciated
Sometime ago I bought an IBM Valuepoint 6384 325T (386SLC , 8 Mb RAM) , which has a 3com Etherlink III 3C509 , with one rj45 port. I installed WFWG 311 and it picked up on the same installation and everything was fine , I was able to connect to my FTP server to download games and stuff.
The case needed some love so I took it to a friend for restoration because I suck at such things.
I got the case last saturday , shiny and beautiful , but the 3COM refuses to work..., The green led is on
So far I tried
1. changing the slot
2. running the 3c5x9cfg program , It doesn't detect the card..I tried the pnpdsabl.bat no results
3. Installing the card in my trusty K6-2 pc , 3c5x9cfg detects it and i have tried setting some irq and base address combinations (there is some combinations more i could try but it appears IRQ 10 and port 300 are free in the IBM) and I also tested it with no errors. But when i reinstall it on the IBM it doesn't detect it.
So it works on the k6 but not in the ibm
So far i think i'll do this
take out battery and power from the ibm
use a toothbrush with isopropylic alcohol and clean the riser connectors , also the 3com card.
Plug and pray
do you have any other ideas that i could try? Thanks
