First post, by Lostdotfish
Just wondering if anyone remembers which 2GB kits (2x1GB DDR1) were good for overclocking on AMD S939?
I remember Winbond BH5 (or UTT) and Samsung TCCD being very high performers but they topped out at 512MB a stick if I recall correctly...
Struggling to find a good lead on high quality kits that will do high overclocks and good timings.
I have an OCZ Platinum kit that I think is Infineon ICs. It's currently running at DDR333 (rated to DDR400) with my Opteron 165 doing 333x9 for just under 3GHz. I have to run a massive divider to keep them running. The moment I try and push them at all, the wheels fall off...
Reply 1 of 5, by agent_x007
Search for 400MHz CL2(.2.2.5), with more frequency with same timings being best option (and 2.3.2.5/8 being next best thing).
Reply 2 of 5, by Xplo
Ballistix PC4000 (original 56278 P/N - Z503.16TD with Micron -5B rev D chips) were undeniably the best reaching 290-300+mhz consistently, in the right hands, at 3-3-3-8. These also had a very high failure rate and as such are incredibly rare today. Crucial brought out atleast 2 more P/N's & revisions .16TD1 & .16TD2 which seemed to improve the failure rates somewhat but were based on newer chips -5B rev G & F, I think, but were also not as strong at reaching the same OC heights, 260-290 was more realistic with these ones again at 3-3-3-8. Speculation that the failures were either PCB or SPD chip issues rather than the memory chips themselves.
Other options are Samsung UCCC, G.Skill PC4000 HZ is fairly obtainable and they regularly acheive 260-280mhz at 3-4-4-8, some examples known to get upto 300mhz. Key with these is low volts. Start as low as 2.2v and step your way up. Adata Vitesta PC4000 Extreme Edition also have a reputation of getting top clocks as far as UCCC go.
Then you have Infineon CE-5/6, Mushkin Redline XP4000 and Corsair XMS4400PRO are among the top kits with these chips IME, these chips are known not to do well at high clocks in 3D though, artifacts and crashes. For example, 285mhz which is towards the ceiling of what you can expect at 3-3-2-8 could be Prime/SPI32M stable all day long, but wont be 3D stable. Again in my experience, 3D stability is somewhere upto 10mhz lower than synthethic tests.
The XMS4400PRO across many samples I have are consistently getting upto 260mhz at 2.5-3-2-5, 270+mhz at 3-3-2-5 and 280mhz+ at 3-4-4-8 which are their rated timings. They are also the fastest and only 2GB set to be released above PC4000, so some good heritage too.
My favourite are the Ballistix (& Tracer's with the same chips)
Top tip with any 2GB set, start at low volts and step yourself up through the clock range. Start at 2.5v (2.2v with UCCC). Sub-timings are very important too, add voltage as a last resort.
Reply 3 of 5, by Xplo
With regards to your current setup, as a quick test find the closest memory divider that will put your ram around the 220mhz mark. Adjust timings to 2.5-3-2-5, set voltage to between 2.7-2.75v (actual). If your getting failures, then I would expect either the CPU to be unstable at it's current clock rate, a weak memory controller on your CPU sample, or an issue with your sub-timings, which may be a result of your motherboard not giving you enough control over them in the BIOS, if the latter you can use something like A64Tweaker from inside windows.
What's the stepping of your cpu, and what is the voltage (actual) at 333x9, and have you completed both 8hr+ P95 blend (two instances) at your current settings stated and one pass of SPI32M? Eliminate the CPU/BIOS settings as the issue in the first instance.
Reply 4 of 5, by Rav
You want any random sticks that have Winbond BH-5 chips on them.
If you are lucky you can get good sample that can run at DDR400 speed at CL1.5... or instead at 500-550 @ 2-2-2-5
Reply 5 of 5, by Lostdotfish
Rav wrote on 2024-07-15, 02:51:
BH5 / UTT do not exist in 1gb sticks.
