First post, by Xenphor
edit: Right after making this post I tried it again and now it boots normally? Wtf? Is it dying?
Here's a video of the problem.
I just received a 9200 from ebay that looks to be in excellent shape. I put it in my system and it worked straight away. I ran 3DMark 2001 1 time so that I could warm up the heatsink to replace the paste and it ran fine, so I powered down the system and took out the card. I had already removed the pushpins, so it was only a matter of wiggling the heatsink free and removing the dried up paste. I couldn't completely remove the dried paste around the very outer edges of the GPU where it dips down into the PCB because I didn't want to risk damaging it. This seemed okay since the top was wiped completely with Arctic Silver Arcticlean kit. I put on some Noctua paste, put the heatsink back on and everything looked fine.
I put the 9200 in my Win98 pc and immediately I got no signal from the OSSC. I tried many times but nothing happened. Finally I took the card out, cleaned the contacts and made sure it was firmly in place. After doing that I get a signal but it is full of garbage although I can at least make out the boot up sequence.
I really don't understand what could've happened?
