Reply 920 of 1151, by snipe3687
I don’t suppose there’s gerbers for this are there? I don’t mind paying the price for it but I like building them. I honestly don’t even need one with the PicoGus being available now but I do like to have actual hardware for some situations vs emulation.
Reply 921 of 1151, by CHA0SHACKER
I have a weird bug. When using Ultramid I sometimes get hanging notes in Tyrian 2000. is that normal?
AMD K6-III+ 400 ATZ @ 550 MHz 1.8V | Gigabyte GA-5AX Rev 5.2 | 256MB 100MHz SDRAM CL2 | 32GB SSD (SSD370S) | 3DFX Voodoo 4 4500 32MB @ 183MHz | Orpheus II LT with X2GS-SE Wavetable | Gravis UltraSound PnP (clone) with 16MB SIMM
Reply 922 of 1151, by keropi
CHA0SHACKER wrote on 2024-05-26, 10:22:
I haven't had this so far - but ofcourse Tyrian sound system is so weird it would not surprise me to have more issues than we already know
maybe it worths to test a different ram stick on your gus card - that's all I can think atm
Reply 923 of 1151, by CHA0SHACKER
keropi wrote on 2024-05-26, 12:19:
Damn, didn’t happen in other games so far. I don’t have other compatible RAM at the moment. I‘ll do some more tests, thanks.
EDIT: Really only affects Tyrian. So it might just be Tyrian being weird again. I‘m generally finished with tinkering now. Here a few final pictures:
The attachment IMG_9848.jpeg is no longer available
The attachment IMG_9849.jpeg is no longer available
The attachment IMG_9850.jpeg is no longer available
Reply 924 of 1151, by Grue
I have an Orpheus 2 and a p233Mmx machine.
I had a problem running orpheus.bat in autoexec.bat, which worked only on every 2nd boot. The problem was that the env wasn't set.
When env wasn't set, the orphenv.bat was present in the c:\orphinit directory.
The solution to this problem was to add the "timeout 2" command into the orpheus.bat file between running orphinit.exe and calling the env.bat
I tried to run this with and without smartdvr.exe with the same result.
I'm running MS-DOS 7.1, and I have a 4 G B CF card as a mass memory with one large fat32 partition.
Reply 925 of 1151, by Gonzogar
Hi there,
After my P1 mmx died I'm trying my Orpheus II on a P3 win98SE machine.
The problem is that after inserting the card (with a x16gs wt) into the ISA slot and rebooting the system, windows recognises the card as Ultrasound PnP, but it doesn't install nor found any driver for it. After messing around I managed to get into windows but GUS is not working so everytime I reboot i get this "viwd.vxd" error...
I thought that windows should install the drivers automatically but it doesn't seems to be the case.
Reply 927 of 1151, by Gonzogar
Marmes wrote on 2024-06-16, 20:29:
Hello!
Please visit https://pcmidi.eu/orpheus2.html for instructions. You will find a nice guide there. Cheers!
I feel so dumb, I was trying to install with the same files I did it for my mmx machine which was DOS based...
I'll take the opportunity to make a dual boot better
Reply 928 of 1151, by Gonzogar
I managed to install the drivers without issue on Win98SE, but one question has arised (haven't tested) If I reboot to DOS do I need to install the DOS drivers in order to make them work properly? Would that overwrite Win98 drivers?
Sorry if it's silly...
Reply 930 of 1151, by Gonzogar
I did a clean install of Windows 98SE and managed to get Crystal and GUS working without any trouble, however, 2 weird things are happening to me right now.
The first one is that OPL didn't work after installing the drivers, so I had to manually reinstall them, after that OPL sounds but is WAY TOO LOUD in comparison with other MIDI solutions (like FM or GUS)
The second one is that no matter what I do, I can't get an external device to work, I'm currently with a Roland MT-32 and can't get sound out of it. I tried to manually Add a compatible MPU-401 hardware but the result was disastrous I have to reinstall Windows altogether because I found myself on a startup loop (mouse cursor showing and no service loading)
Reply 931 of 1151, by Gonzogar
Did a third reinstall of Windows and now I got a BSOD when trying to install the Yamaha/OPL driver from the Windows 98SE CD...
Reply 932 of 1151, by keropi
Gonzogar wrote on 2024-06-20, 23:42:
none of what you describe is normal behavior , I suspect something else is going on with your system
manually adding the Roland MPU-401 device is normal since it's not a PnP device
you should make sure you are not having any resource conflicts (ports, irq) and also make sure that the default pcmidi IRQ2 is actually available in your system , you might have to use another IRQ if the target system is anything newer than a p1
Reply 933 of 1151, by Gonzogar
This are the BSOD I got.
Reply 934 of 1151, by Gonzogar
keropi wrote on 2024-06-21, 06:14:
none of what you describe is normal behavior , I suspect something else is going on with your system manually adding the Roland […]
I'll try to change the IRQ
After my post I did a 3rd fresh install and managed to get almost everything working but when I installed the Roland I lost the OPL, after trying to reinstall it in device manager it asks me for msopl.drv from the Windows 98SE CD, If I put it it fails and then shows me the BSOD I just posted.
After that I install the driver that is in the pcmidi website but even though it appears as a MIDI device it has no sound.
Reply 935 of 1151, by keropi
you should be able to use the orpheus2 driver for the OPL installation - windows should auto-detect some "adlib gold opl3" device , you can leave as-is or tell windows to look at orpheus2 crystal driver for the rebranded driver
in the end you should have these devices -for the CS4237 part of the card:
also try and reserve irq/dma from BIOS , it will certainly help
and also try to setup your chipset/vga/controller drivers before installing any sound ones
sadly the windows bsod codes etc don't translate to anything useful AFAIK
Reply 936 of 1151, by Gonzogar
keropi wrote on 2024-06-21, 19:21:
you should be able to use the orpheus2 driver for the OPL installation - windows should auto-detect some "adlib gold opl3" devic […]
Gonna start from scratch again... I did install all the devices shown in your picture, however choosing OPL didn't produce any sound until I installed the "win98" driver, but then that clashed with the pcmidi or something else.
Reply 937 of 1151, by Marmes
Please describe us your system.
Reply 938 of 1151, by Gonzogar
My system is:
Pentium 3 1.0 ghz
Motherboard Biostar M6VCG
512 MB RAM
HDD 10GB
IDE to SD 128GB (not formatted yet)
Voodoo 3 1000 AGP
Orpheus II (connected via midi out to a Roland Mt-32 or SC-55, not gameport)
Third Windows 98SE install.
Installed only the first driver (Crystal) before GUS and PCMIDI. Sound is working, kinda but it doesn't stop any sound keeps on a eternal loop. For MIDI, FM is working, but OPL even though it appears as installed doesn't produce any sound.
I'm still thinking about installing the GUS and PCMIDI part...
Reply 939 of 1151, by keropi
Gonzogar wrote on 2024-06-22, 02:57:
[...]sound is working, kinda but it doesn't stop any sound keeps on a eternal loop. [...]
that means there is an irq/dma conflict , you should go to device manager and see what is allocated for the crystal devices
