First post, by NarakuITA
Hello everyone. I would like some help or advice to ask for. I have this laptop with Windows 2000 in perfect working order, obviously the battery is now out of production and none are found in working order. I was wondering if it is possible to use an external device to use the PC without having it connected with the cable to the electrical outlet.
I was thinking of using a Power Bank as a battery, obviously you need a cable that connects the laptop to the Power Bank.
This is the power supply. If I'm not mistaken it's 15V right? If so, you just need to figure out the size of the circumference of the wire attachment.
I found this, maybe it should be fine. Hopefully someone more knowledgeable can confirm.
https://amzn.eu/d/4UCgbrz
Now all I have to do is find a Power Bank suitable for the laptop.
Are there any suggestions?
