First post, by ux-3
All my plextor optical drives will fail to open the tray when empty. They make periodic noises and are trying to open, but they don't. After many attempts, they finally open. If you then close, they are likely stuck again.
HOWEVER, they do eject right away if they have a disk inside. The problem only occurs without a disk.
My first assuption was, that the rubber ring sticks to the above counterpart. I cleaned the mechanism with alcohol, but the problem still occurs.
I am nearly certain that it must affect all Plextor drives out there, so you will likely have seen it too, if you have a Plex.
Any info on this?
Retro PC warning: The things you own end up owning you.
