PSCSI Disk Emulation success!
First post, by JodieC
I really hate dedicating storage to old PCs. I'm not sure why - and the idea has always tickled my fancy that I should definitely be able to emulate a SCSI disk somewhere else. I did it a long time ago and I bet it's even better today.
So, without further ado. What I'm doing so far, what I've ordered, etc. I'm just going to be pasting links, photos and configs and stuff.
Cards that may support target mode:
Adaptec PSCSI cards seem to have explicit callouts in their product sheets when they support target mode. There have been mentions in product literature back to 154x cards.
I've seen indications that QLogic cards may support target mode, but have not seen extensive documentation to it.
Drivers for PSCSI target mode:
FreeBSD:
ahc - https://www.freebsd.org/cgi/man.cgi?ahc(4)
ahd - https://www.freebsd.org/cgi/man.cgi?ahd(4)
I found an interesting discussion here about someone having issues with FreeBSD target mode, and this actually included a lot of helpful info for getting started
https://forums.freebsd.org/threads/help-with- … -example.56828/
My setup is this:
ESXi VT-d passthrough of an Adaptec 39160 to a FreeBSD 12.0 machine
Custom compiled kernel with these options. As I have a 160 controller, it's covered by the ahc driver and these options are specific to the ahc driver. I tried a 39320 and it didn't work.
`include GENERIC
ident SCSIKERNEL
device scbus
device da
device targ
device targbh
options CAMDEBUG
options AHC_TMODE_ENABLE=0x127`
(I went really wide with the bitmask. 🤣)
I made that config file, compiled the kernel and rebooted. It's a lot easier than it sounds.
https://www.freebsd.org/doc/en_US.ISO8859-1/b … fig-config.html
https://www.freebsd.org/doc/en_US.ISO8859-1/b … g-building.html
Okay, now what?
FreeBSD includes a usermode scsi target application in /usr/share/examples/scsi_target . Go in there and run `make`
If you have your file or disk for the backing store, you are ready to try. However you need a piece of information first - the bus number of your ahc controller (or whichever controller. To get this information, you'll need to run `camcontrol devlist -b` .
If you have something like a 29160 or a dual bus controller, you'll see two controllers, one for each channel. Picking the wrong one is easy - however a lot of devices will reset the channel when they initialize the IC and you'll see "something reset channel A" on your FreeBSD console or messages.
So in my case the 39160 was on scbus33 and scbus34. You can define these manually with some hints files if you really wanted to.
I have two 20GB disks given to the VM from my SSD stores. They're in the system as /dev/da1 and /dev/da2
Now to fire up the target:
`tmux`
`/usr/share/examples/scsi_target/scsi_target -W16 33:1:0 /dev/da1`
(When I don't do -W16 for 16 bit transfers, nothing shows up on the initiators)
If this went well you'll see messages about sending CCBs and blah blah blah. If it says your controller doesn't support target mode, you may have the wrong controller number, or it may be that your controller really doesn't support target mode. I've read that Adaptec Ultra320 adapters 1) might not do target mode if set to Ultra320 speed, 2) Later models might not do target mode at all.
OKAY, the client now. I want to install Windows98 on something!
I drop the 39320 into the client and connect a VHDCI cable to the 39160 in the ESXI box.
Now I'm going to power down that FreeBSD VM. Then I make a new VM in ESXI for Windows98, and tell it to use the first 20GB disk I gave the BSD VM. Install until it gets past the text installer portion and shut down. Remove the 98 VM but let it keep the disks.
Boot the FreeBSD box back up and run your scsi_target command again. Ctl-B D to detach from the tmux session and leave it running.
Now on the client, I power up, and I remember to change the initiator ID for the client device, because if they're all ID 7, nothing is going to work. So I change the initiator ID to 0.
At this point, I can go into Adaptec's SCSI bios and see if it will pick everything up. It should be pretty smooth sailing from here. However, I have had instances where the initiator does something, I don't know what, that just absolutely wrecks the target side, and I make it a point that if I reboot the initiator, I just go ahead and reboot the target VM too, because it seems to tweak the target on reboot.
I'm going to splat more things here as I come across them.
    1.58 MiB
Reply 2 of 20, by JodieC
A couple of other notes - this may only be important for setup:
It looks like, at least for now, only 2 HDDs are recognized by the machine. This may be because the 39320 isn't actually supported by 98SE and the drives are just passing through with Int 13h.
One of the things I like in this setup is that I can quickly just prep an image and sling it to the machine as a whole SCSI disk. It's making the driver setup very easy in machines that have no other peripherals. I don't need to find a CDROM, floppy, any of that crap. If it needs something before network is up, it's a reboot away.
Reply 3 of 20, by doshea
JodieC wrote:
Adaptec PSCSI cards
When you say "PSCSI" do you mean "parallel SCSI"? I don't think that "PSCSI" is a conventional abbreviation for that, is it?
I found that a few weeks ago myself, but unfortunately have not had the success that you have! Anyway thanks for your post, it's good to know that this does work in FreeBSD 12.0 for someone so that I don't have to go back and try some of the older versions that I had seen success reports with.
I think you mixed up hex and decimal there, if you want it to be 127 shouldn't it be 0x7F?
I found your post in your "Ca 2000 PC - Albatross - PIII 1GHz, GF2, iSCSI XP" thread where you said:
JodieC wrote:
I reworked the FreeBSD PSCSI emulation using the CTL tools in FreeBSD.
The storage block device is emulated via PSCSI through the Adaptec 39160s on each end.
This seems much, much, much more robust and reliable than the scsi_target userland example. Doesn't hurt when it's decent for speed.
That sounds good! For now since I know nothing about CTL tools I'm happy to just have one command to run, but I assume CTL would mean the ability to maybe emulate a SCSI CD-ROM drive too.
Edit: Was it difficult? Are you planning to publish and/or contribute a patch for it?
I'm using an Adaptec 2940 and when my initiator machine (which I think has an Adaptec 2920) is POSTing and gets to the SCSI BIOS initialisation, I get a kernel crash due to a page fault with lots of spam in the 'dmesg' output in the core.txt file:
ahc0: Someone reset channel A
(targ0:ahc0:0:1:0): targdone 0x9747c00
(targ0:ahc0:0:1:0): ahc0: Someone reset channel A
targread
(targ0:ahc0:0:1:0): targread ccb 0x9747c00 (0x2827a460)
(targ0:ahc0:0:1:0): targreturnccb 0x9747c00
cam_debug: targfreeccb descr 0x9736e20 and
cam_debug: freeing ccb 0x9747c00
(targ0:ahc0:0:1:0): write - uio_resid 4
Sending inline ccb 0x10 (0xffbfe658)
(targ0:ahc0:0:1:0): getccb 0x1cc6ef00
Changing abort for 0x28270000 to 0x1c4fd000
(targ0:ahc0:0:1:0): sendccb 0x1cc6ef00
targreturnccb 0x1cc6ef00
etc.
I gather that with improper termination you can get signals reflecting, and I might not have gotten that correct, so maybe this is causing some unrealistically huge number of resets or other commands to be received. The Adaptec 2920 I'm using as an initiator doesn't even have a hotkey to enter its BIOS so I can't check on the termination settings there, nor ask it to scan the bus as in your screenshot 🙁
Reply 4 of 20, by JodieC
doshea wrote:
JodieC wrote:
Adaptec PSCSI cards
Yes just parallel SCSI. I'm probably just making up the PSCSI acronym. I since found that LIO uses the term pscsi as pass-through SCSI so there's likely to be an overrun in acronyms.
Right. I fixed it later but I haven't updated my post.
It's all off the shelf stuff, CTL is much easier and can load easily at boot. I do plan to publish my ctl.conf file shortly. I'm running into a bug where my Win98SE box just constantly resets the bus and CTL is unhappy about that. I started over with a fresh FreeBSD 12.0 box, recompiled kernel and I'm starting to install 98SE today.
I'm using an Adaptec 2940 and when my initiator machine (which I think has an Adaptec 2920) is POSTing and gets to the SCSI BIOS […]
targread
etc.
I would bring up your FreeBSD 12 box, not run the scsi_target, and see if you get reset spam on the bus in dmesg when you boot the other machine. The other lines about the ccbs are fine. You won't need them when it's up and running, you can recompile without CAMDEBUG turned on.
Reply 5 of 20, by JodieC
Just writing up the CTL stuff
My ctl.conf
target eui.943d07ce77ecc404 {
port ahc0
port ahc1
lun 0{
path /root/floppyimg
lun 1{
path /dev/da1
lun 2{
path /dev/cd0
The target EUI doesn't matter, I made it with `openssl rand -hex 8` . CTL requires an EUI, IQN or NAA number here though.
sysrc ctld_enable=YES
Compile the kernel with the targ drivers (mine looks like this)
include GENERIC
ident SCSIKERNEL
device scbus
device da
device targ
device targbh
Here's what my CTL command outputs look like on boot:
root@bsd3:~ # ctladm portlist -v
Port Online Frontend Name pp vp
0 NO camsim camsim 0 0 naa.5000000d40cfc701
Target: naa.5000000d40cfc700
All LUNs mapped
port_type=8
1 YES ioctl ioctl 0 0
All LUNs mapped
port_type=4
2 YES tpc tpc 0 0
All LUNs mapped
port_type=8
3 YES camtgt ahc0 0 0
LUN 0: 0
LUN 1: 1
LUN 2: 2
port_type=2
4 YES camtgt ahc1 0 0
LUN 0: 0
LUN 1: 1
LUN 2: 2
port_type=2
root@bsd3:~ # ctladm lunlist
(7:1:0/0): <FREEBSD CTLDISK 0001> Fixed Direct Access SPC-5 SCSI device
(7:1:1/1): <FREEBSD CTLDISK 0001> Fixed Direct Access SPC-5 SCSI device
(7:1:2/2): <FREEBSD CTLDISK 0001> Fixed Direct Access SPC-5 SCSI device
root@bsd3:~ # ctladm devlist -v
LUN Backend Size (Blocks) BS Serial Number Device ID
0 block 4096 512 MYSERIAL0000 MYDEVID0000
lun_type=0
num_threads=14
file=/root/floppyimg
ctld_name=eui.943d07ce77ecc404,lun,0
scsiname=eui.943d07ce77ecc404,lun,0
1 block 31457280 512 MYSERIAL0001 MYDEVID0001
lun_type=0
num_threads=14
file=/dev/da1
ctld_name=eui.943d07ce77ecc404,lun,1
scsiname=eui.943d07ce77ecc404,lun,1
2 block 0 512 MYSERIAL0002 MYDEVID0002
lun_type=0
num_threads=14
file=/dev/cd0
ctld_name=eui.943d07ce77ecc404,lun,2
scsiname=eui.943d07ce77ecc404,lun,2
I'm trying to boot from floppy img but I may have to just make a 98 system disk on a FAT disk and boot from that. No big deal if I have to, but I thought I would try the lowest intervention way possible first!
Reply 6 of 20, by doshea
I've done that a few times, and just get a single "Someone reset channel A" message each time.
I noticed in /usr/src/sys/conf/NOTES (if I recall the path correctly) that there is a setting to make something (CAM? the target layer?) only respond after X number of milliseconds, so I'm considering trying that to see if maybe it helps me to get an idea of what is going on. I kind of wish I had some kind of SCSI protocol analyser, like Wireshark for parallel SCSI. I assume such things exist(ed) in very limited numbers for those with lots of money!
Thanks for the CTL information! I'll have a read through it later.
Reply 7 of 20, by JodieC
I would like to add a small note that I was able to pass through an ISO from my VM to the SCSI bus, as a CDROM, and it was bootable to the client.
Since my SCSI card is set to boot ID 7 lun 0, I removed everything and set the lun 0 to be the cdrom. You have to specify a device type of CDROM (5) when making the CTL lun
ctladm create -b block -t 5 -o file=/mnt/os/Microsoft/WinXP/WinXPwSP3.iso
With that, my ISO was bootable on the initiator.
I haven't had much luck with 98SE yet because I guess not all 98SE disks are bootable to begin with. Even the one I have that shows bootable in the initiator's SCSI BIOS won't actually boot at boot time. The SCSI BIOS detects the boot sector on the CDROM but then at boot time it says "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
The biggest difference I can see, looking at the ISOs with `isoinfo -d -i $imagename` is that the 98SE disk looks like this:
    Eltorito defaultboot header:
Bootid 88 (bootable)
Boot media 2 (1.44MB Floppy)
and the XP disk looks like
[b] Boot media 0 (No Emulation Boot)
[/b]
Going through my other bootable images, my 98SE disk and Red Hat 5.2, 6.1 and 6.2 are the only ones with Boot media 2. sigh.
I know I just lamented my journey in reasons why it wouldn't boot. However, I found that since I had the FDC controller disabled, it would not boot from Boot media 2. Who knew?
It booted from the emulated SCSI CDROM now, however, once it gets to the PCI bus scan after the AIC-7890/7891, it's hanging.
So I have more to dig into.
Reply 8 of 20, by mil
Very cool.
I do something similar with Fibre-Channel, FreeBSD and ZFS and/or RAM backed volumes (mdconfig). I also have a Fibre-Channel router/bridge that should allow me to use plain old SCSI like your setup.
The reason I use ZFS volumes is snapshots, rollback and clones (it takes less than one second make a clone of a LUN). Kind of like you can do on a VM. (remember to use volmode=dev for zfs volumes)
Messed up? Just rollback to an automatic snapshot 10 minutes ago.
Trying out 10 different chipset drivers? Just make 10 clones after installing Windows but before installing the drivers (only the differences take up space).
I have not yet tried the SCSI bridge part yet. But I do have a machine with Windows 98 that boots directly of a SAN LUN using a PCI-Express Fibre Channel HBA. It does not have a driver for the HBA so it just uses the "INT 13" access that the HBA provides via its BIOS option ROM. Benchmarks are strange and inconsistent (see screenshot). There are however drivers for Windows XP and up, and that works great.
I also use this for my main workstation that normally runs Linux and FreeBSD, but I do have a Windows 7 LUN that I sometimes use to play The Witcher 3. I just shut down, switch the LUN to the Windows 7 one and boot (my network is setup in such a way that there is no network access when running windows).
I also have snapshots so I can rollback to before installing drivers, patches, etc.
I used this setup to do 40 almost fully automated installs of Windows 98 controlled from a shell script. Trying about 40 different combinations of parameters to Windows 98 install setup.exe.
The script just put "setup.exe" with the specified parameters in autoexec.bat in each LUN before booting the machine.
All that was missing was the ability to cut power to the machine from the script. I have since then solved the power control issue with a network controlled APC PDU.
If I had a VGA capture setup (working on it) I could start a script to run an experiment and view the results later as video files. Off-cause the LUN of each variant is snapshotted at the end, so I can just choose any one of them later, and boot that setup. Automating Windows 98 stuff beyond the install is a bit hard, but it is doable. It is also fairly easy to emulate a PS/2 or USB keyboard from something like an Arduino, if the need should arise.
Since I built that setup I have acquired some PCI HBAs that should allow me to do this on older machines. But still no drivers and just "INT 13" access. When I have time to play with the FC/SCSI bridge/router, it should allow me to present the SAN LUNs via. plain old SCSI. Then I can hopefully use normal SCSI controllers with drivers and everything.
It has been a few years since I really played with this on anything older than my main workstation.
Another benefit with this setup is when running FreeBSD or Linux, is that they are not tied to the hardware the same way as Windows.
This allows me to boot a LUN that is normally used by a physical machine as a VM (bhyve). I use this for my GF's workstation that runs Xubuntu. It can be booted as a VM during the night for automatic patching. It is fairly easy to detect from a script during boot if it is running as a VM, and then do any patching needed, and then have it shut it self down after patching. It is off-cause important to make sure the physical machine is not running and also to cut off FC access to the LUN while it is running as a VM. I also use snapshots before and after patching.
    47.51 KiB
Reply 9 of 20, by doshea
I had a brief look around for such a product recently and it didn't seem like there's anything available that is relatively cheap. Do you know of any, or does one just need to get a lucky find on eBay or something?
I've done something similar on Linux with qcow2 disk images, which you can expose as a local block device using qemu-nbd. I haven't gotten to the point of seeing whether I can expose those via FC though.
This all sounds like a nice setup, being able to do snapshots of a physical Windows machine would be great!
Reply 10 of 20, by doshea
Unfortunately I was just thinking of this:
# SCSI_DELAY: The number of MILLISECONDS to freeze the SIM (scsi adapter)
# queue after a bus reset, and the number of milliseconds to
# freeze the device queue after a bus device reset. This
# can be changed at boot and runtime with the
# kern.cam.scsi_delay tunable/sysctl.
and it defaults to 5000ms anyway (verified using sysctl).
Anyway thanks, using CTL was slightly more successful (and also looks more promising in terms of features!). Here is what showed up in /var/log/messages when the initiator machine booted:
kernel: ahc0: Someone reset channel A
syslogd: last message repeated 998 times
I guess 999 resets isn't good for that scsi_target daemon but CTL can handle it.
The SCSI BIOS on the initiator was able to identify that there was a target device there on FreeBSD, but then when I booted into (very old) Linux on the initiator and loaded the kernel module for the SCSI card, after some more of those reset messages, the module reported timeouts and no devices showed up in /proc/scsi/scsi. I think it's time to try some different HBAs on both ends.
Incidentally I get these messages when FreeBSD boots:
kernel: Configuring Target Mode
kernel: (ctl0:ahc0:0:6:0): Lun now enabled for target mode
kernel: (ctl1:ahc0:0👎ffffffff): Lun already enabled
kernel: (ctl1:ahc0:0👎ffffffff): ctlferegister: Enable LUN failed, status 0x3e
kernel: ctlfe_online: CAM error LUN Already Enabled for Target Mode (0x3e) returned from cam_periph_alloc()
kernel: ctlfe_onoffline: ahc0 has no valid WWNN/WWPN
kernel: ctlfe_onoffline: ahc0 (path id 0) failed enable target role: 0x16
kernel: .
I noticed "failed enable target role" first and was concerned, but then it looks like for some reason it's just trying to enable it more than once so maybe this is normal? It obviously works to some extent.
Reply 11 of 20, by JodieC
Mine does that too, it's because of the AHC_TMODE_ENABLE in the kernel config.
I'm not sure why your bus would reset 999 times, that's pretty nuts. I'd definitely get a new initiator.
Reply 12 of 20, by doshea
The huge number of resets seems to be related to the SCSI HBA I'm using for the initiator, since with different ones I only get 1 or 2, but I don't think that they are actually a problem.
I did have some success, and it seems like my problems are related more to what software is running on the initiator than on the HBA itself. Generally the worst things to run are Linux (I tried Red Hat Linux 7.3 or Fedora Core 1) where I either can't see the device or get fatal issues under high load, or FDISK under DOS which also has fatal issues.
On the system I already mentioned with the AHA-2920, as I already said "The SCSI BIOS on the initiator was able to identify that there was a target device there on FreeBSD" but Linux couldn't see anything, but when I boot into DOS the BIOS provides drive letter(s) for the partitions I already had on the disk, and I can also boot from the virtual disk, so there the issue seems to be with the Linux driver (fdomain).
On another machine with some other (mostly Adaptec PCI) HBAs, I could at least mount the virtual drive under Linux and see the filesystem, but if I tried to use 'dd' to copy the entire virtual disk to /dev/null, FreeBSD started dumping out errors and the Linux system would hang. On the other hand if I booted into DOS or Windows 95 or 98 SE, I could see the disk and run ScanDisk and do a full surface test with no problems. The only issue under those non-Linux OSes was if I ran FDISK it tended to cause similar problems with errors and hangs. If I disabled the SCSI BIOS and loaded ASPI drivers under DOS and ran AFDISK I had problems too.
I did manage to get AFDISK working when I used one particular old ISA HBA, but with that one I still had trouble under Linux, so I haven't found any combination that works completely yet.
I tried a few cards for the target too, it didn't seem to make any difference.
One solution I found to not being able to run FDISK was getting ctld to export the same disk via iSCSI, attaching to the disk on my Linux system, then configuring Bochs to emulate the same geometry that I know the HBA does and running FDISK under Bochs. An alternative would be using Linux's fdisk, enabling DOS compatibility mode, and then forcing the geometry using special commands, but I'd rather let DOS pick sizes that it knows will work anyway.
My end goal is to use this for a Macintosh, but when "Drive Setup 1.5" does a drive scan it causes a FreeBSD kernel crash.
Edit: I'd forgotten to try changing the HBA's settings to slow things down. Changing from wide 40MB/s to narrow 5MB/s and disabling disconnection seems to have helped the issues under high load from Linux at least. I'll need to do some more testing.
Reply 13 of 20, by TMM
doshea wrote on 2019-07-20, 03:37:
I've been working on this and with a lot of help from FreeBSD developers most of this should be fixed. In FreeBSD 14.1 (not yet released) this should "just work" with ahc(4).
Reply 14 of 20, by doshea
TMM wrote on 2024-04-23, 02:18:
Wow, cool, thanks!
Would these fixes be in FreeBSD-14.0-STABLE-i386-20240418* as available at https://download.freebsd.org/snapshots/i386/i … SO-IMAGES/14.0/ ? I don't care too much about how stable it is as I'll install it on a machine that isn't doing anything important.
I feel like it'd be good to try this out sooner rather than later, as I imagine bug reports are probably more useful - and more likely to be addressed - while things are still fresh in everyone's mind, and also I see from https://www.freebsd.org/platforms/#_supported_platforms that this is expected to be the last major version to support i386, and I just happen to like to use some small, older machines for this kind of thing.
In case it's not obvious, I don't know too much about FreeBSD, so any suggestions are most welcome!
Reply 15 of 20, by TMM
It would be in FreeBSD 14.1 that is about to come out (3 - 4 weeks I think?) , but you could build your own kernel from git and use it now though! The last patches to make it stable only just landed (https://github.com/freebsd/freebsd-src/pull/1190). I'm still working on a somewhat user friendly way to create multiple targets as well, as right now you can only make multiple luns on a single target. I do have that working but patches for that are not yet public (see attachment):
Note that I'm using x86_64 to test with, I'm using (very cheap) pcie->pci bridges to use the adaptec cards with more modern machines.
I can write up a blog post on how to set this all up if you'd like, it'll take me a few days.
Reply 16 of 20, by weedeewee
TMM wrote on 2024-04-24, 10:59:
Sweet ! Now to find the time&space to actually try this out, set it all up, enjoy it, etc.. sigh.
Do not ask Why !
Reply 17 of 20, by doshea
Oh, fair enough, thanks for the link! I'm a bit lazy and would prefer to avoid building a kernel initially; it looks like maybe the stable builds are weekly and there should be another one soon?
Nice! I thought I had created multiple targets in the past; is it just that that was something that has to be done at a lower level without your patches, or am I completely misremembering? 😁
Hmm, very interesting! I'm aware that these sorts of things exist but not aware of how to really use them practically, e.g. how to secure them inside a chassis. I'd be interested if you could explain that part, or share a photo, or something. For example I imagine that if I had a quite small mainboard in a large chassis, and I got one of those bridges and attached it to the PCIe bus via a cable, perhaps the bridge board could be screwed into the chassis next to the mainboard so I could screw the PCI cards into slots?
Thanks! Have the commands changed much since FreeBSD 12.0 (when I last got this stuff working)? If not, I can probably figure it out again, particularly if the drive my command history is on still works 😁
Reply 18 of 20, by TMM
doshea wrote on 2024-04-26, 01:01:
Probably! But you'd still have to rebuild the kernel with options
AHC_TMODE_ENABLE=0x7f
regardless! Work is also still ongoing, like making the CD emulation compatible with old initiators like DOS ASPI drivers only landed yesterday. (https://github.com/freebsd/freebsd-src/pull/1202)
This wasn't possible before without having multiple cards, or writing your own target software! Previously it was only possible to make multiple LUNs on the same target. So you could make multiple devices, but not all initiators will support multiple LUNs, particularly of different types. Like Windows 98 will not understand having a target with one LUN that is a cdrom, and another LUN that's a harddisk. At least I haven't been able to make that work.
Devices like this: https://image.allekabels.nl/image/4199544-0/d … -riser-card.jpg in combination with a low profile adaptec scsi card like a 29160LP (https://scsi4me.com/images/products/854/334/8 … /29160LPas.webp) will work, alternatively adaptec did make some pcie cards based on those same chips which are basically just a pci chip with an integrated pcie bridge. All of this will "just work", pcie to pci bridges are part of the pcie standard!
Not a lot has changed. You have a few more options now. I'll write some guide for it when I'm done probably anyway, as the information is a bit scattered around. This thread is actually one of the better sources available right now!
Reply 19 of 20, by TMM
I created a PR that should negate the need to compile a kernel to use target mode here: https://github.com/freebsd/freebsd-src/pull/1208
It hasn't landed yet, but when it has you can just enable target mode with a device hint on /boot/loader.conf
