First post, by Roman555
Hi All,
Inspired by Vlad94's experiments in his topic Dual Core CPUs on Intel i915 and i925 chipsets I acquired Asrock 775XFire-VSTA. I even hadn't started to tinker with dual-core CPU-s yet as the mainboard denied working with my Radeon HD5450 PCIe graphics. It just didn't post. I was disappointed. But It did post with it in the PCIe x4 slot. A GeForce 8600 ran well in both PCIe slots. I googled and found some pieces of evidence of incompatibility this model (and also others) with relatively newer graphic cards.
Long story short, a new PEG init procedure was successfully ported into Asrock 775XFire-VSTA bios.
If you bump into the such weird problem you can find the bios-mod in attachment.
Everything at your own risk. Good luck!
P.S. Link to AFUDOS engineering version
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 1 of 1, by Roman555
P.S. At the time It was tested only in WinPE
