mothergoose729 wrote on 2024-02-07, 03:07:
IMO unmodified socket - fastest CPU at launch compared to fastest CPU available is the only fair way to consider it. Taking the slowest CPU a socket supports and comparing it to the fast CPU that can be hacked to work is disingenuous IMO.
The problem with slot 1 and socket 370 is that the CPUs at release were too good. A 333mhz pentium II was available at launch for slot 1 and the fastest slot 1 drop in replacement is katmai@600mhz. You need slotket adapters to make copper mine work which is not really the original socket anymore.
Erm, not exactly, the wait to 333mhz was a long one and the 300mhz variant which supposedly launched in May alongside the 233/266 was vaporware in the computer shopper 6 months (nobody would accept orders or put you on the waiting list if you tried to force order one). Maybe different for name brands but I didn’t know anyone with a 300mhz p2 until almost 1998 as none were on the shelf, even if you had deep pockets.
So I’m not sure how much that matters but yes compatiblity issues did abound in that era, theoretically stuck at 66mhz FSB (possibly 75 or 83 if you had a board that could overclock) on launch edition boards which realistically limited you to a rare 733 celeron.
Now to expand, I owned a socket adapter for socket 8 ppro, that allowed you to install socket 370 chips, the 733 celeron I had seemed to work in the ppro motherboard .
In terms of platform if we include ppro we have 133mhz-1400mhz using the architecture.
I think socket 5 is probably the winner. You could get a brand new socket 5 board with a Pentium at 66mhz in 1994 and that was top of the line. Later you could buy a 3.3v Pentium MMX @ 200mhz as a drop in replacement - more than tripling the clock speed and giving you MMX.
Nope, your thinking socket 4 which was 5 volt and 60/66mhz and using a socket adapter could be upgraded to 400mhz
Socket 486 is another strong contender. At launch in 1989 the fastest chip available was a DX 25mhz.
Technically the dx20 launched in April as release candidates and was available earlier than the June 486dx25 launch , oddly Intel had to do a recall and late redesign of the 486 motherboard for reasons I forget. Ah well.
Technically it's possible to run a 486sx@16mhz and a AMD 586dx@133+ mhz on the same board. But you would need to modify the board a lot in order to do it.
Modify? Not really, I owned a very early Micronics ISA only 486 motherboard with a socketed crystal, the motherboard was designed under the assumption that you had to match the cpu and crystal, besides the voltage needing adapting there was really nothing stopping you from installing any 486 cpu, technically even the 5x86-150 would have been fine on the board as it didn’t seem to be much affected by high or low bus speed crystals.
