Jimbo_J wrote on 2024-01-27, 16:30:
Thanks for this I really appreciate the help. The board is a rev 2/3 one with 5 PCI slots and the bios currently on the board is 3.1. The board will post with 2x SL2U7 P2 450 CPUs so I know the board is working. I tried the 2x SL43F P3 850 CPUs on the 8.5 jumper setting (even though as you mention it shouldn't affect the CPUs) and they just would not post. I will try again later once I've updated the bios version you've shared though I'm starting to think that the p3 850 CPUs are just dead.
I've re-checked in case I was misremembering the boards cpu support, but my P6DBU (rev 1.1) definitely supports coppermines. Here's some pics of that check with latest BIOS at both 100MHz (AUTO / default) & 133MHz (BIOS OC) fsb x 7.5...
The attachment Cu_SL4BS.jpg is no longer available
The attachment P6DBU_Cu Boot.jpg is no longer available
The attachment P6DBU_Cu POST.jpg is no longer available
The attachment P6DBU_Cu Speedsy.jpg is no longer available
Another thing to check is the cpu VRM chips on the board. At some point after release, Supmrmicro switched the VRM chips from Harris HIP6004ACB to either HIP6004BCB (what mine has) or HIP6004CB - only the last two support Coppermine voltages, though for some reason Supermicro claim that this switch didn't occur until rev 2.xx PCBs. The chips to check are marked in this last pic.
The attachment P6DBU_Cu VRM.jpg is no longer available
