C0deHunter wrote on 2023-09-03, 17:56:Since P4 Northwoods is underpowered for these games, what games / period should I consider installing on this machine then?
On a Northwood running XP? Probably... the same games you'd play on a 98SE machine.
C0deHunter wrote on 2023-09-03, 17:56:1) I mean if I have to compromise for a 2000~2003 era, wouldn't a powerfull PIII (which I have) would be suffice to play 2000~2004ish era games?
Most likely, yes...
Keep in mind that that the 1GHz PIII came out in March, 2000. The first Northwoods came out in January, 2002. That's a less than two year gap. And the first wave of socket 423 Willamettes were slower than the higher-end PIIIs; I think it's only when Willamettes hit 1.7 or 1.8GHz that they matched/exceeded PIII performance.
The P4 might be much better for a 2004 game, but then you're back at the problem that a 2006-era C2D will dramatically, dramatically outperform the Northwood, not to mention that opens the door to PCI-E GPUs and there are a lot of XP-friendly PCI-E GPUs with much higher performance than an AGP card on a Northwood.
C0deHunter wrote on 2023-09-03, 17:56:2) What is a Pentium 4 good for anyways? I am so baffled, because back in the day I used to own multiple P4 machines, and they were OK/capable at playing games.
How about... heating rooms in winter?
I had a Pentium 4 back in the day, too, a Willamette actually that I built two weeks before the Northwood launch, complete with RDRAM. Also had a Deleron socket 478 system I built for a stupid project to make a MythTV PVR (total money pit of a project that turned out to be). Go back to articles from the Conroe launch in 2006, e.g. Anand's piece at AnandTech, and you'll see what the world was like - mediocre P4s that ran hot and were bought mostly by business folks, excellent Athlon X2s paired with chipsets some people didn't trust - and then suddenly you get a lineup of processors that beat the P4/P-D at every single benchmark. I still had my aging Willamette until then, simply because of how mediocre the P4s/P-Ds were and how I didn't want an AMD (I actually think I was very close to getting the AMD when the first rumours of Conroe came along), and then I absolutely rushed to get an E6600.
The Pentium 4 is forgotten largely because of the 2006 launch of the C2D platform, followed by the C2Q. Every piece of software you might ever want to run on a 2004-era Preshot will run just fine on a Conroe, just... at twice the speed and something like half the heat output. And the C2D/C2Q, at least if fed with enough RAM, will run 64-bit Windows 10 or unofficially 11 just fine, run modern web browsers just fine, etc. Then maybe two years later, Intel followed that with the 45nm C2D/C2Qs with a huge, huge drop in idle power consumption.
Arguably, the P4 has a place as a vintage 98SE machine - you can get a higher-performance 98SE machine out of a higher-clocked Northwood/Prescott/etc than a P3, at least if you're an Intel fanboy. If you're not an Intel fanboy and you can find a board that doesn't have bad caps, I suspect you may be better off with an Athlon XP Socket A board for 98SE. And that's why you can buy a Pentium 4/D chip on eBay for way less than the cost of Socket A Athlon XPs... (trust me, I have a Pentium D 945 in an anti-static bag to show for it.)
