DFI K6XV3+ REV: B and K6-2+/570MHz
First post, by haker120
Is this AGP board capable to accept this processor with or without L2 cache mod? I got annoyed with my S7 mobo so I ordered that SS7 for AGP. 😁
Reply 1 of 47, by majestyk
It´s one of the best suited mainboards for K6-2+ and K6-III+ CPUs.
The latest BIOS wouldn´t hurt.
Reply 2 of 47, by Nemo1985
It's not a bad motherboard but for sure with standard bios is not a top performance with vanilla bios but worry not, there is the soggi modified bios which improves the performance of memory (and l2 chip if I remember right).
With that bios it reaches the performance of Aopen AX59 PRO and other mvp3 motherboards.
Reply 3 of 47, by haker120
Then I need to install new BIOS but which one? And I paid 350PLN what is around $76,01. 😁
Reply 4 of 47, by Nemo1985
The bios modified from Soggi, it's a vogon's user you can find it there: https://soggi.org/deliver/
Reply 5 of 47, by majestyk
haker120 wrote on 2022-08-05, 10:12:
The "fair" price depends on the L2 cache size. This board was availsble with 512KB, 1MB and 2MB L2 cache. The 2MB version is quite rare.
If you run a K6-2+ or III+ you don´t have to worry about that since the onboard L2 becomes L3 cache that´s not so critical for performance.
Reply 6 of 47, by haker120
Well, my mobo is this:
Reply 7 of 47, by majestyk
At least one SRAM chip is not populated so this one has either 512K or 1M.
The attachment 9O9IcgBa.png is no longer available
There´s usually a small sticker at the LPT-connector indicationg L2 cache size.
Reply 8 of 47, by TrashPanda
majestyk wrote on 2022-08-05, 12:13:
IIRC both of mine have only one and its 1Mb but you can upgrade it to 2Mb if you have the soldering skills.
Reply 9 of 47, by majestyk
I´ve seen several 512K versions on Ebay recently. In this case it´s more soldering work and the 128Kx64 chips are 128-pin and have a very fine pitch.
This would only make sense if you need a cacheable area of 512MB RAM AND plan not to use a K6-2+ or K6-III or K6-III+ CPU.
Reply 10 of 47, by haker120
This, I bet it's 512kb. 😀
Reply 12 of 47, by haker120
Still patched BIOS applies?
Reply 13 of 47, by TrashPanda
majestyk wrote on 2022-08-05, 12:18:
Yeah, I was thinking of upping to 2Mb on one of the boards but like you said the pins on the ICs are ...beyond my ability to remain focused on . .even with a scope, also the shakes make it doubly difficult to solder tiny stuff.
But 1Mb of cache is more than ill ever use for these boards which rarely need more than 128mb of ram.
My boards are Rev B2 and AT format, same board just different layout.
There is an AT version of this board with 1Mb up on Evilbay right now, Id buy it but no shipping outside continental US.
Reply 14 of 47, by majestyk
haker120 wrote on 2022-08-05, 12:29:
Patched or latest official BIOS
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
As for performance just make sure that you are using a K6-2+, K6-III+ or K6-III CPU, then you can neglect the small L2 cache. Otherwise don´t exceed 128MB RAM and everything will be perferct.
512K L2 -> 128MB RAM cacheable
1MB L2 -> 256MB RAM cacheable
2MB L2 -> 512MB RAM cacheable
Reply 15 of 47, by haker120
So what will happen if I'll put 512MB RAM with 512kb L3?
Reply 16 of 47, by majestyk
IF you´re running a 6-2+, 6-III+ or 6-III CPU you´ll be happy, because both the CPU´s L1 and L2 caches will cover all of the 512MB RAM. The 512K L3 cache has very little effect on memory performance, just a few % so it can be neglected.
Reply 17 of 47, by haker120
So K6 570 will be ok even overclocked to 600MHz without cache mod? 😀
Reply 18 of 47, by majestyk
If you mean K6-2+ 570 @ 600 MHz - yes!
Reply 19 of 47, by Repo Man11
Vogons has a thread dedicated to benchmark racing Super 7 systems with 3D Mark 2000, so if you want to know exactly what difference CPU and motherboard cache makes on performance it is well documented there. All evidence indicates that the best MVP3 motherboards with two megabytes of on onboard memory cache and an overclocked K6-3+ will be among the top scoring systems, but the slightly superior Ali Aladdin chipset Super 7 motherboards are the record holders. If you aren't interested in benchmark racing, the performance difference is likely irrelevant to you.
AMD K6 3DMARK, aiming for stars.
