Reply 80 of 84, by Dennis1959
dr.zeissler wrote on 2024-05-30, 07:25:Because I am always using multiboot I have to stick to cards that are compatible. - 1370 does not work in amithlon, 1371/1373 do […]
- 1370 does not work in amithlon, 1371/1373 do work with native support with the original kernel.
- 1371/1373 did not work for me in plain dos and win9x doswindow/fullscreen (SBEMU works for real dos) on my Scovery 211/212 ALI5 Chipset (the only PCI soundcrd that workd was ESS-SOLO1 PCI on that machine, every other card was correctly installed but muted)
- 1371/1373 did not work for me in OS/2 Warp4, but there was a driver for 1371 that should work in OS/2 but is not supported in Win/OS2.
- Never tested Win3x on it.In short:
- I will test your dos-driver for 1373 if this works at all and if it's better than SBEMU at current state
- I don't think SBEMU will work with the win3x-driver but I will test this too.
- A working solution for win9x doswindow/fullscreen would be pretty nice, I already tested several different drivers, none worked. Seemed to be that it is the same issue like in plain dos.Doc
Hello, I stuck 19.00 on my cash app, and also have it linked to my PayPal, how much is the shipping that you mentioned?
Thankyou.
